Wanted 1.8m dish in merseyside/nw england
Stejc
DM800, Motorised Triax TD88, 45W to 39E. Digital+ HD subscription, TNTSAT HD Card.
Southport
Is anyone selling a 1.8m solid dish in Merseyside or the North West in general?
Ste
Nowhere near you but I do have a Laminas 1.8m in the garage doing nothing.
I have a solid, petalised 1.8m reflector here in W London, also doing nothing. It's almost certainly the Jonsa manufactured model.
WHATAGOAL1
2.4, 1.8channelmaster, tm5402, tech1500, db920
Leic
1.8 channel master dish
Stejc
Southport
Thanks but I have a petalised dish at the moment but it is a cheap one which I think isn't the best especially as I am using it for KU band so I'm actually looking for something non-petalised to replace it and hopefully motorise further down the line.
Thanks for the clarification, your profile doesn't mention a dish other than the Triax.
Ah, you mentioned it in the Es'Hail thread but not the model.
Petalised dishes can be used on Ku band and if carefully set up can give reasonable results, but yes, the IRTE 1.5 one-piece always outperformed the 1.8m when I was asked to improve reception.
WHATAGOAL1
Leic
only dish no arms, no stand
Stejc
Southport
Thanks Channel Hopper, its a no name Chinese petal dish, cheaply made and rusting, cost around £40 second hand but I believe they are only £100ish new.
