51.5E Belintersat 1
anto@
italy
8/9
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18", Superjack 3618, Moteck Vbox2, IBU PLL Single, DM900 RC20 UHD 4K" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single, Edision OS Mini 4k" "Tivusat Gold Card & Cam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
I finally got this satellite, with Gibertini OP125L
Chr0nik
TM-9100 Linux receiver / Edision OS mini 4K / TM-2600 M3 motor / 110cm dish (34.5w to 50e) - 100cm dish (51.5e/52e/53e/60e)
Grays, Essex
Has the minimum dish size for this sat changed? I'm able to get almost everything in between 34.5w and 52e but I'm not able to get this bird and 60e.
51.5E Belintersat 1
Is a tricky satellite for me on the Raven Mesh 88cm set up I get all satellites from 53E to 45W
But one transponder on 51.5E 11290 H 45000 keeps breaking up,
The other 2 11230 H 45000 & 11350 45000 working OK,
On my OP Gibertini 100 XP set up I get 52E & 50E to 45W with no problems,
But on 51.5E I get no signals at all :eek:
11290H 45000 is a tricky one to lock here too.The rest of the tps are ok. 11290 is dropping in & out of lock
pontiend
Contibruter
south yorkshire
I have not looked here for some time.This is what I get on my 100cm orbital dish in South Yorkshire.I notice that Sport 5 is Fta just now on 11289 H 44944.
Edit. As said above it is dropping out of lock.Pixelating
Using the cheap - scrapper - DRO LNB on the 80cm orbital .20200801_204056.jpg
So, 52E is bleeding in.
nelson_b
Contributor
O.k here with no breakup on 1.2 Channel master and Octagon sx88+ optima
Showing 15 db locked on my F15 receiver from the same dish ... but no pictures ..... it reports - no audio / video ??
On a fixed zone 2:
11230H 45000 13db, 11290H 45000 bouncing between no lock and 12db, tried a few LNBs with little noticeable difference. On an Edision Primo:
All our kit cant be having a bad day. It must be a transmission issue.
Chr0nik
Grays, Essex
Chr0nik
Grays, Essex
Forgot to mention that I've been trying to get this on a 110cm dish but cannot get this sat - this one and 60e.
nelson_b
Contributor
On a fixed zone 2:
11290 h 45000 is certainly an odd transponder ... Having a bit of time to spare today i tried different receivers on this one from a 1.2 channel master.
Octagon sx88+ optima ..... perfect reception - no glitches or breakup
GT Media / V 7 HD ...... perfect reception - no glitches or breakup
DR HD F15 .... 15 db good signal no droput - all channels scanned in - all info displayed - despite this - No audio /video on any channels
Technomate 5302 HD ... good signal but drops out every 5 seconds or so - scans in all channels but just as numbers - not names - no program info either . ... No audio /video on any channels
Skybox M3 HD ..... No signal - Transponder not recognized ... 11230 H 45000 is recognized though ??
I must say Rebel T.V on 11290H 45000 has been playing a pretty good selection of rock music all afternoon :cool:
Same behaviour on my Openbox v8s.
Managed to get 11290 to peak at 12.5db but still not a stable lock on the Primo.
nelson_b
Contributor
Its a weird one .... moving my 1.2 dish off the satellite slightly shows that it needs fully 12.5 db to run the Optima - i get slight break up starting once below that
My Test on August 3rd 2020
88 cm Raven mesh dish + Inverto Black Ultra 0.2 (0.1E 51.7N)
....................................11230 ......11290.....11350
SX88 4K UHD..........84%........0-82%.........84%
SX88+........................84%...........84%.........84%
SX88 Optima..........87%.........0-82%........84%
Edision Primo S2....84%.........0-82%........84%
TM5402HD M3......12.5dB......0-12dB....12dB
TM6902HD............77%..........75%.............74%
Only the SX88+ & TM6902HD displayed all FTA TV without signal break up.
pontiend
Contibruter
south yorkshire
This morning I did some longitude adjusting for my dish.That increased the quality fron 89 to 93 %.I got good video and sound.Checked again just now to confirm that it was not a fluke.Still good lorry racing on now.
TBS6983 100cm Dish
