deeptho
- Apr 7, 2006
- Age
- 57
- Wavefrontier T90, Laminas 120cm, 2 other dishes; tbs 5927, tbs6904, tbs6909x, tbs6903x, tbs5990, tbs6981,tbs5927
- Europe
This seems to be a problem with media_build.@deeptho
Hi deeptho, My building of the kernel has come to a halt, seemingly stopping where it applies patches to the existing kernel, 5.4.0-26-generic.
I've no idea what hunks are, too deep down in Linux language for me.
I'm using Linux Mint 20 on an HP Envy laptop. Any ideas what the problem could be?
TIA.
Code:david@david-HP-ENVY-dv6-Notebook-PC:~/deeptho-tbsdriver/media_build$ sudo -s [sudo] password for david: root@david-HP-ENVY-dv6-Notebook-PC:/home/david/deeptho-tbsdriver/media_build# make dir DIR=../media make -C linux/ dir DIR="../../media" make[1]: Entering directory '/home/david/deeptho-tbsdriver/media_build/linux' rm -rf drivers include sound mm .patches_applied .linked_dir .git_log.md5 git_log kernel_version.h Searching in ../../media/Makefile for kernel version. ./use_dir.pl ../../media sync file: include/uapi/linux/uvcvideo.h sync file: include/trace/events/pwc.h sync file: include/uapi/linux/smiapp.h sync file: include/linux/of_graph.h sync file: include/uapi/linux/v4l2-common.h sync file: include/uapi/linux/cec.h sync file: include/trace/events/v4l2.h sync file: include/uapi/linux/max2175.h sync file: include/uapi/linux/ivtvfb.h sync file: include/uapi/linux/v4l2-mediabus.h sync file: include/uapi/linux/media.h sync file: include/linux/via-core.h sync file: include/linux/pci_ids.h sync file: include/linux/overflow.h sync file: include/uapi/linux/media-bus-format.h sync file: include/trace/events/vb2.h sync file: include/linux/dma/xilinx_dma.h sync file: include/uapi/linux/cec-funcs.h sync file: include/linux/dma-fence.h sync file: include/linux/dma-buf.h sync file: include/uapi/linux/v4l2-dv-timings.h sync file: include/uapi/linux/xilinx-v4l2-controls.h sync file: include/linux/mmc/sdio_ids.h sync file: include/uapi/linux/meye.h sync file: include/uapi/linux/videodev2.h sync file: include/uapi/linux/v4l2-subdev.h sync file: include/linux/kconfig.h sync file: sound/pci/bt87x.c sync file: include/sound/aci.h sync file: include/uapi/linux/v4l2-controls.h sync file: include/linux/ti_wilink_st.h sync file: include/uapi/linux/ivtv.h sync file: include/linux/hdmi.h sync file: include/uapi/linux/lirc.h sync file: include/linux/fixp-arith.h sync file: include/misc/altera.h sync file: include/uapi/linux/usb/video.h sync dir: drivers/staging/media/ sync dir: include/uapi/linux/dvb/ sync dir: drivers/media/ sync dir: drivers/misc/altera-stapl/ sync dir: include/linux/platform_data/media/ sync dir: include/media/ sync dir: include/dt-bindings/media/ make[1]: Leaving directory '/home/david/deeptho-tbsdriver/media_build/linux' root@david-HP-ENVY-dv6-Notebook-PC:/home/david/deeptho-tbsdriver/media_build# make allyesconfig make -C /home/david/deeptho-tbsdriver/media_build/v4l allyesconfig make[1]: Entering directory '/home/david/deeptho-tbsdriver/media_build/v4l' make[2]: Entering directory '/home/david/deeptho-tbsdriver/media_build/linux' Syncing with dir ../../media Applying patches for kernel 5.4.0-26-generic patch -s -f -N -p1 -i ../backports/api_version.patch patch -s -f -N -p1 -i ../backports/pr_fmt.patch patch -s -f -N -p1 LeavingLeaving-i ../backports/debug.patch patch -s -f -N -p1 -i ../backports/drx39xxj.patch patch -s -f -N -p1 -i ../backports/v5.7_mmap_read_lock.patch 1 out of 1 hunk FAILED 1 out of 1 hunk FAILED 1 out of 1 hunk FAILED 2 out of 2 hunks FAILED 2 out of 2 hunks FAILED 3 out of 3 hunks FAILED 1 out of 1 hunk FAILED The text leading up to this was: -------------------------- |diff --git a/drivers/staging/media/atomisp/pci/hmm/hmm_bo.c b/drivers/staging/media/atomisp/pci/hmm/hmm_bo.c |index 4fb9bfdd2f4c..76d6e52b7af9 100644 |--- a/drivers/staging/media/atomisp/pci/hmm/hmm_bo.c |+++ b/drivers/staging/media/atomisp/pci/hmm/hmm_bo.c -------------------------- No file to patch. Skipping patch. 1 out of 1 hunk ignored make[2]: *** [Makefile:133: apply_patches] Error 1 make[2]: Leaving directory '/home/david/deeptho-tbsdriver/media_build/linux' make[1]: *** [Makefile:387: allyesconfig] Error 2 make[1]: Leaving directory '/home/david/deeptho-tbsdriver/media_build/v4l' make: *** [Makefile:26: allyesconfig] Error 2 root@david-HP-ENVY-dv6-Notebook-PC:/home/david/deeptho-tbsdriver/media_build#
There are two things you can try:
* make sure that you did a "make distclean" before building. No .o and .ko files should be present; also
make sure that you have the mst recent media_build
*It could be some unneeded driver. If you can find which one, you can disable it.
I suspect the problem also occurs when building the tbs media_tree. It is then also kernel dependent.
Switching to a slightly older linux kernel version may help.
media_build is quite complicated. I don't understand all the details either...
