Help Required 800hd se
danko74
Dream Multimedia DM800se Clone
West Midlands
Hello everyone,
I just reflashed my Dreambox DM800SE (Sunray Clone) with OpenPLi 6.1 (2018-01-03-develop).Stupid question:why I can't see all the satellite but just Hotbird 13.0 and Astra 19.2 under the Tuner section? The tuner card is a BCM4505 (DVB-S2).Is it a firmware issue or tuner card issue?Thanks
Mickha
North West
How have you set up your tuner?
What is your satellite setup, fixed dish system,, several LNB's, and Diseqc switch, motorized dish?
You might want to check the satellites.xml file, using Filezilla, or other program, to see what satellites are listed.
dig deep
Prince of Birthdays
Dream7020 and AZ Elite and a few DM800
Sweden
Start with a re-install just to be sure all files was OK
danko74
West Midlands
Hello, It works now...I had to reboot and set the right Satellite on the tuner configuration(stupid me)
I'd like to test some cccam cline but I can't find anything of good.Any advice?
Mod. Note Redacted text due to Forum policy re. methods of reception.
