Channel master c120 feed horn wanted
RimaNTSS
Some SAT-related hardware.
N-E from Riga
What am I missing?
As it is already said, you are missing the adapter (consists of 2 halves). If you do not find the original one, I could try to make one for you. That would be more universal than original.
Sorry the spare one I have doesn't fit the CM feed horn.
That would be great
Sorry the spares don't fit on the CM feed horn.
CM adapter on the left, the middle one is marked 3040735-03, right one 3040666-02. All have arrows pointing to antenna.
edit: do not search for the first model number, some quite disturbing results appear :eek:
Chris James
None
Southampton
That would be a great help many thanks
Just keep having problems
So they do (Not that I checked ....... )
As per the other feedhorn thread, I will take some dimensions this weekend, the feeds that I had were for receive and transmit and may have a waveguide that is tuned for uplink frequencies. Receive characteristics in the 11-12GHz band would be less important, opening the guide diameter by 1mm may help improve things.
OK, found one (eight bolt fitting, plus slot for chip fork dielectric plate) . Internal diameter is 18mm +/- 3% which from the formulae I am used to equates to a functional frequency range of 10.5 - 12.6GHz.
The minimum cut off for a circular waveguide at this diameter is 9.75 GHz, with upper in the region of 14.5 GHz when other factors take over creating losses, making a mid-range near 12.5GHz, which suggests an increase of the internal diameter from 18 to 19mm should assist in propagating the Ku band that everyone here is used to receiving with a universal LNB.
I still doubt Channel Master have messed up the focal point of their range of antennas (much less Andrew / Raven not picking up on the flaw) once buying up stock and then manufacturing of the same items.
Chris James
None
Southampton
All very technical but to be honest I just want my setup to work not looking for the last bit of signal right now just want a working system I’ll worry when I get my foot in the door
I think that a 1,2 meter dish will do what I want it to do for now I would like to go c-band but dish size might be a problem
I still don’t know what I’m gonna get with my 1,2 channel master dish
zorrin
Specialised contributor
France
www.facebook.com
france
The black adapter, dimensions in this post:
I will post the 3D files as soon as possible.
zorrin
France
www.facebook.com
france
