Wanted Polariser barrel
butchyboy
channel master 1.8m motorised on c band,ku band,1.2 metre prime focus irte dish, 1.85cm offset mabo dish,vu+duo & 42 HD lcd tv
ireland
Now to find a signal on c band with V polarity
butchyboy
ireland
guys am i on 40.5w?
connectados con dios
canal antigua
gallo sports
go-tv
ltv
all this channels coming in around 10.db mark on 3711 H 8330
doing a rescan as i peaked the dish on them above channels i found on the first scan.
guys am i on 40.5w?
canal antigua
gallo sports
go-tv
ltv
Yes butchyboy, you are on 40.5W where there is some nice juice.
Are you gonna have a look for 55.5W now that you are up and running?
butchyboy
ireland
moonbase can you throw me put some strong V frequenceys on 55.w
also anyone know where i can down loads a sta list of c and ku for my dr hd f15 thanks
butchyboy
ireland
having trouble trying to get channels up on my viark sat 4k,only options in the configuration i can see is for ku,how do i add c band frequenceys etc
butchyboy
ireland
sorted thatchanged lnb type to 5750/5150
butchyboy
ireland
scanned in about 37 channels on H and 70 odd on V on 40.5w,i guess its my 1st attempt a c band stuff.
but not a smell on espn or foxsports,although maybe thats cause i was only mounting it today to see could i get some channels.
probaly has to be tweaked and picked for any hope of espn and foxsports?.or maybe my dish is just not big enough?.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
butchyboy
ireland
RimaNTSS
N-E from Riga
First, LNB should be properly placed and pointed towards the surface of the dish, then the dish should be properly pointed towards the satellite. And finally, yes, the dish could be bigger to attract more satellite signals.
And one more thing.... to get the best performance of the satellite system, the illumination angle of the feed should be equal to the opening angle of the dish.
butchyboy
ireland
well my dish has been fine on ku band for the last 2 years so i am happy enough with the way it is,the ku lnb holder that came with the dish slides on to the arm and can be pushed in nearer dish or back out.that lnb holder cannot adjust up or down so it was manufactered for the dish and the 3 arms so where it is sitting is pointing correctly as it comes that way from the factory.
butchyboy
ireland
hi guys received the servo r/c for turning the probe and just tryed it here in the house for a test and doing a great job :)
have attached some pics and a video.
cannot seem to be able to upload the video?.
butchyboy
ireland
hi guys theres the link to my video of the probe being turned to H and V.
