- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
Why don't you like it ? If it is quiet and works on the cm reflector then stick with it.its up!
hey guys, spent all morning removing polar mount, and aligning and installing whatever this motor is onto the 1.2m - took forever to find 30w with a decent signal.
seems to be ok, and pretty solid, i guess time will tell - winds etc.
i didnt get on with the actuator - might have to flog it - or keep it as backup.
its been a learning curve though - the NON USALS experience.
the dish moves A LOT quicker than Diseqc motor - seems powerful. just hope it lasts
i will move the dish above garage at some point - shattered now tho.
will play some more later, only have a few positions stored.
If you are not happy with the faded sticker then print another.
It does the job, it's fast and I doubt it will break down anytime soon.
The only issue I could nail down with them was an illogical dowel pin arrangement where the lower average intelligence installer forgot to remove a locking screw before pulling the dowel out by tightening an 8mm nut.
