- Jan 1, 2000
- Age
- 59
- Website
- www.sat-elite.uk
- UK
From what I can see the bolt required is one of two motor bolts that keep the cap and canister on top of the gearbox.Well, I have dug dipper into the issue. Removed bolts from 4 actuator motors. 2 of them have Mx95mm bolts, one has M4x85mm bolts and one has threaded rods with imperial thread (very similar to M5, but M5 nut does not fit). I suspect that @butchyboy needs M4x95mm bolt, which I can send. But suspect that sending even a small package to UK will cost something like 5 EUR.
Usually the only time they break is during a dismantle, though I have seen them bend when the path between the magnets is not aligned with the locating pin on some actuators.
