C-Band Extended
anto@
italy
this photo was taken with the dish set at 65 west
unfortunately in front of you you can see a tree and reception is not possible
anto@
italy
I don't understand if this tp is 5 est or 3 est
if you give me some help thanks
anto@
italy
thank you
i am using a lnb without the dielectric
anto@
italy
good signal today
65 West. Extended C-band.
4688 H. 3749. 2/3. 8PSK. ID: CH2. Biss.
Static pic at the moment
View attachment 144665View attachment 144667
Nice one, I think you are the only current UK member of the forum to have published pictures from these extended upper C-Band frequencies from 65.5W unless @nelson_b has sniffed them out.?
I have no chance of a line of sight from my gaff, nowt after 47.5W for me. I have a two bob merchants arc, down in the bottom of a valley surrounded by trees and houses.
nelson_b
Contributor
No ... no pictures - only the transponder locks from way back in 2020.
Iv'e put the Norsat 8000RI 3.6-4.8GHz lnb with the 5750 LO back on the rig to double check that GTMedia in their latest v18 firmware for the Combo had fixed the IF blind scan range [it only did a partial amount before due to a bug]. Can't run the External 5G filter on it though due to it's 3.7-4.2 GHz pass band, so the DX out of footprint Brazil stuff from 70West at around 3.7 GHz area get's hammered
Same as me MB, I cannot get anything after 47.5W either..
Manikm909
Small'ish Dish Man
Kent, UK
fortunately - i can get 55.5w and 58w - placed my dish with that in mind.
I had plans to relocate my Precision 2.0m dish to get line of sight further west
However, I experienced a setback when my next door neighbour refused me permission to use their ground floor flat roof extension !
Manikm909
Small'ish Dish Man
Kent, UK
inconsiderate neighbours!!!
dreamsat
germany
40,5° West
otokoc
DM920HD
prodelin1244
Balikesir,Turkey
2.4m offset prodelin 1244 and Norsat 8000RI
from Balikesir,Turkey
MrDish1
Delta Star
Qth:Aalten
Hello members , is it true that the feedhorn with lnb revolves around the outside of the AV-Comm of member ;otokoc. and if so, does that work? Best regards
Using the picture as a reference, and assuming the OMT itself is not motorised - the AV-Comm poloriser will be in a fixed position, usually with the wording to the side and the internal 'steps' running vertically and the scalar ring attached to the front of the barrel. The OMT will be inserted into the poloriser barrel with one port at the top and the other port 90deg to the side with identical lnb's attached - this configuration will give you H / V pol only. Rotating the same OMT 45deg within the fixed poloriser barrel will give you LHC /RHC polorisation obtainable from the lnb's.
Manikm909
Small'ish Dish Man
Kent, UK
Nice one @John I learned something there. I will give my pipe another go now that my replacement 1.8m dish is up. I expect more from it than a vipersan plate
