28e levels in south france
I'm not sure how your dish is currently mounted but could you attach some brackets to the existing fence post so the dish is moved away from the fence to stop it interfering?
dmaavrigdo
1.2m Laminas OFC1200 dish
Inverto Quad Black Ultra IDLT-QDL412-ULTRA-OPN
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
Yes the ground support will be my problem too, I assume if permanent I will set it quite deep in concrete hole whilst ensuring it is totally perpendicular (to earth) etc. My problem at present is that my 120cm dish I decided I dare not place on the roof, and happen to have a fence post in a great position and more or less well aligned, issue is it is not perpendicular, the fencing interferes with the back of the dish alignment so the readings are not true, oh and the fence pole is not round so minor sideways adjustments are tricky - it has been a journey but still it all works now thanks in no small part to the support from here.
Once I am 100% that the dish is not changing location I will invest in a fixed post etc. Are there any instructions on this - and or recommended suppliers ? or is it simple a case of having something like a round scaffolding pole sunk into the ground in concrete ?
Lag bolts through pole clamps into fence post.Spacers to adjust pole tilt
jhalliday45
Setting up still bought a 125 dish for France and planning to use old Sky HD for Freesat
Cazeres
Yes hadn't really considered that - I had considered a scaffolding post over the fence post (I think it will just fit and concreting that in place) but this looks a better alternative, will see what I can do thanks.
jhalliday45
Cazeres
Hi all, and thanks for the help so far, as I had an excellent image for ITV4 - for the tour de France, I had not further tinkered with the dish. However that is now finished and having discovered I only seem to have 2E and 2G channels I have been trying to search out 2F but I am just getting absolutely zero, not even close to a signal for them.
The quandary is that 2E & 2G are quite strong am getting BBC TWO HD near 100% perfect all the time, and am loathe to deviate too far from that - and being frank I don't think I should need to, I am assuming this is mm work now given I am well aligned to 2E & 2G.
Any further tips at all please on how to find 2F channels ?
dmaavrigdo
Octagon SF8008 twin
Yamaha HTR-2067
Vansbro Sweden
BBC2 HD Luxury!
If you really want 2F I think a slight tweak to the west will be required.
  • Screenshot 2021-07-22 at 15-51-00 Satellite motion charts for ASTRA 2E,ASTRA 2F,ASTRA 2G based...png
jhalliday45
Cazeres
BBC2 HD Luxury!
Yes BBC1 &2 in HD, but don't watch them much...all I want is Dave in SD :D
Will give it a try again this evening when the heat has gone and signal may be better. thank you
4wd
Getting the picture
5 W, 9-13-19-28 E
2f eu is surely strongly present, try 12148 H. The 2f uk's are the weakest of anything on 28e, needs the right dish size + working out -the- alignement. The pictures shows an example of the local (north of Nice) eu-uk difference.
My rule of thumb, if any eu beam not 'at least' at 100% 17dB, I'd experience trouble of some sort (weather, seasonal, time of day, dish size, alignement, whatever) for stable reception of some\many of the uk's.
jhalliday45
Cazeres
OK so after much weeping, wailing an gnashing of teeth as I aligned the dish I decided to do some proper analysis of which channels I have and do not have. I thought I was missing AStra 2G because I don't have 4seven which should be on 2G however in fact I do have other channels on 2G , same across 2E and 2F.
In summary it seems I am just missing a few transponders ;
Astra 2G 11127V (for 4seven) and
Astra 2E 12129V (for Dave Yesterday etc)
Is it simply that these transponders may have lower signal strength ?
or could it be an issue with my LNB ?
I have 3 receivers here (4 if you count my scanner);
Arris Freesat 4K
Old Sky HD
Enigma 2 (cannot use due to misplaced remote)
both the Arris and the Sky box cannot find any signal on these transponders even when I do a manual search specific only these numbers etc.
Any ideas please ? or do i just have to live with it ?
4wd
Getting the picture
5 W, 9-13-19-28 E
11127V you should get as you have other 2g's, but that one is for some reasom extremely sensible to correct lnb skew, try turning the lnb very slightly while monitoring the results. I use that transponder for skew adjustment.
12129V is on 2f uk, weak, around 2-3 dB lower here than the best 2e uk's, so may fall under your dish size's reception capabilities, am suspecting you are right on the edge for the other uk's you receive. But may appear once the lnb skew is adjusted.
Also, try adjustments at different time of the day, signals varies in strength.
Good work getting so far! My impression, dish size is on the very limits, think about going up 20cm or so and things will work very well, with some headroom for rain and seasonal changes.
jhalliday45
Cazeres
excellent will try with the skew - I think it is 80% right so will be minor adjustment - thanks again, really appreciate the help
4wd
Getting the picture
5 W, 9-13-19-28 E
Hello from france, ref 28e levels in south france and some previous posts.
Finally got around to dig and look for solid rock, found it 50 cm under the grass, and was able to build up a solid 40cm deep square of concrete to secure the 60mm pole. Only took 2 years lol. And needed 15 meters of trench for pvc water pipe for 2 cables. Well protected.
As for the 28 levels, not tested as this summer stay in France came and went fast (how come time runs away when one gets older?) without me installing the 130 dish. But well prepared for next year with a solid pole fit for the job.
rodscha
So,how is your dish doing?
I realise that one of your beacons has vanished,the 12129 on astra F
4wd
Getting the picture
5 W, 9-13-19-28 E
AtOM13
near Marseille
Triax 100cm, lnb Inverto black Ultra
CM120cm Laminas 150cm
Marseille
Since frequencies changing, 11126 MHz seems to be the weakest frequency here, but all frequencies are locked without problems! CM1.2M 1000033362.jpg
