South Tenerife
FOGGIE
Seatel controller
south Tenerife
Yes, that's the TP frequency 12070 minus the LNB High Band Local Oscillator frequency of 10600, presenting 1470 to your decoder.
For low-band Transponders, the entry you need to make is the TP frequency minus the LNB Low Band Local Oscillator frequency of 9750.
The switchover between Low and High Band is around 11700 MHz, IIRC.
Nice 1 ...you crowd know your stuff
Interesting knowledge thank you
If you press 'services' on the remote, select Options, then scroll across to Add Channels, and input:
11.914
H
27500
5/6
DVB-S
QPSK
Then press yellow, does it find Sky Arts?
FOGGIE
Seatel controller
south Tenerife
11.914
H
27500
5/6
DVB-S
QPSK
SKY Arts i a channel i have. I never knew you could do that on the Sky box. I deffo owe you a 8 pack of lager.
Adding channels like that will put them in the "Other Channels" section of the Options menu. It would be much less faff to use a generic satellite receiver, rather than a Sky box.
11836
H
27500
5/6
DVB-S
QPSK
Should find some channels too.
Manikm909
Small'ish Dish Man
Kent, UK
why dont you just perform a FULL rebuild - wouldnt this bring in all the available channels for @FOGGIE
The Sky 'home' transponder that contains the channel list and EPG data is on the UK beam which the OP can't receive. There may be a way around it by changing the default transponder but I don't know.
FOGGIE
Seatel controller
south Tenerife
You folk amazing...thank you all
Manikm909
Small'ish Dish Man
Kent, UK
Try and get a generic sat receiver for 50 or so euros and then perform a blind scan search to see what u can get
FOGGIE
Seatel controller
south Tenerife
11836
H
27500
5/6
DVB-S
QPSK
FOGGIE
Seatel controller
south Tenerife
I got this message..strange. Because i do have a signal too.
From the hidden installer menu (where you change the default transponder), if you select Manual Tuning instead and enter the 11836H details does it show signal?
If you get a non-Sky receiver you can run a scan and all the receivable channels will be found in one go.
FOGGIE
Seatel controller
south Tenerife
Yeah it did thanks...am still hunting ITV n BBC what ever counties
Sorry but there's zero chance of BBC or ITV from 28.2°E in Tenerife with a 1m dish.
FOGGIE
Seatel controller
south Tenerife
Sorry should not even be said. Yourself and all. Have been amazing. Taking the time out to guide me.
Cannot thank you all enough ..especially ozumo for his top tops.
Thats me addicted to find new frequencies & channels ..lol
If new ones pop up where i can get CH4 . E4 CH5 or any similar ..please let us know.
Any free Football such as Bein Sports too...your all legends...thank you
