- Jan 1, 2000
- Location
- North Nottinghamshire.
Winter project
Convert an Ex Viasat Ku band motorised Pol/Skew unit.
Remove existing Viasat scalar feed, convert to using Channel Master Off-set scalar and adapt the Viasat unit to fit onto the existing CM feed holder, plus - incorporate into the mod the adjusted feed positioning for the 1.2 or the 1.8 off-set Channel Master dishes provided data by RimaNTSC.
1st pic shows progress slightly into the mod - the whole build story to follow.
