Advice Needed SAT+DVB+DAB setup in new home
Forget the stacker. Assuming shotgun cable is up to the job use it to give you two separate systems.
System 1
LNB outputs 1 -> DiSEqC 1.1 switch -> triplexer (with split DVB-T & DAB connected) -> shotgun cable 1 direct to one TV point with satellite.
System 2
LNB outputs 2 -> 2nd DiSEqC 1.1 switch -> 2nd triplexer (with split DVB-T & DAB connected) -> shotgun cable 2 -> split between 2 TV points including one without satellite. May need an amplifier before it is split.
Have you seen that 4 feed Inverto LNB for sale anywhere? If yes be aware it will be a compromise and separate LNBs will give better signal if setup correctly.
Planning a setup
Cambs
System 1
System 2
I don't want to provide another cable. It would need to run all along the three facades and between floors.
Offtensive
Midlands
Do you need external aerials for dab and terrestrial? A small telescopic aerial may work instead.
a33
Specialised Contributor
XSAT410
Rebox RE-9000
The Netherlands
I may consider having just one satellite receiver only with two LNBs as mentioned above
Meaning the quad-feed LNB + the single LNB? So in fact 5 LNBs?
And once inside, you can/want to have multiple cables going from the "box" to the three mentioned receiver locations?
The information is coming a bit ambiguous.....
Planning a setup
Cambs
No, there will be only two SAT receivers and only two LNBs:
a another single twin to cover 28.2 and 28.5.
Planning a setup
Cambs
In that case, can you just not limit the coaxial cable to carry sat only?
Also, what grade/how old is this cable?
If I'd like this to be that simple then I wouldn't ask you guys for help. This a newly build home so cable is like 3 months old now.
a33
XSAT410
Rebox RE-9000
The Netherlands
No, there will be (...) only two LNBs:
I would call that 4 LNBs in one housing.
Or a "quad-feed LNB", never leaving the "quad-feed" out of the expression.
Because functionally you've used up all the diseqc x.0 functionality with this quad-feed LNB; with the other LNB added you already need diseqc x.1. Or maybe not just the original Unicable protocol, but the JESS protocol.
From what I've read superficially about Technirouter, DurLine and SUS21 they may work on just two LNBs, or maybe on 4 LNBs with diseqc x.0.
I'll leave the investigating of that to you, or to others.
When you stick to wanting 2 (added: independant) receivers and 5 satellite positions and just 1 cable, I think you need a Unicable/JESS multiswitch near your dish(es), and I think the quad-feed LNB might be unsuitable for that. So quite an expensive solution.
Greetz,
A33
Offtensive
Midlands
If you can get 90% signal quality using a short coaxial cable, then are you not just over complicating things by adding an external aerial?
Planning a setup
Cambs
Still the problem is elsewhere. How to get two SAT tuners using two different LNBs on a single coax cable.
zorrin
Specialised contributor
France
www.facebook.com
france
sorry to come back with this...
None of those would result in a hole wide enough to accomate 2x standard diameter (approx 8mm each + "cleance") sat cables such as WF100, but the 10 & 12mm bits should allow you to use a single run of CT65 "shotgun" cable - so the required bit size will depend on the cable you choose.
Also, that's a very cheap set of masonary bits and - depending on the hardness of the wall materials - they might get blunted before the required hole is fully drilled - therefore I'd be very inclined to get some better quality branded (such as Dewalt - my preference) bits from your local Screwfix branch in addition to the set above (and those would still be useable for any future jobs - whereas cheap bits probably won't!)
zorrin
France
www.facebook.com
france
@jeallen01 it's just to say that there is a time when the simplest and cheapest of solutions should be considered.
I suspect that there are surely other constraints behind the request of @local system user and I hope that he will find a good solution for him :)
