C-Band Extended
Manikm909
Small'ish Dish Man
Kent, UK
It won't be worth the expense to look at 65West - extended range lnbf needed that covers 4.5 to 4.8GHz plus a larger dish.... i'm only just pulling in enough channel signal dB's on my 2.2 PF Cband system tuned to a knat's whisker of it's life. There's not much feed activity, hardly any, if at all.... and no signals seen in the normal 3.4 to 4.2GHz.
40.5 West Extended is about the same as well re: extended frequency channels.
Ok mate. Thanks.
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
I get 17 transponders on 65w from my location in the southern United States. Transponder 4555V seems to be the strongest of the bunch. Transponder 4555V has two video channels that are usually in English. There are some good movies on this transponder. The rest of the channels are either scrambled or are in Portugese which I cannot understand.
The extended transponders on 61w might be a bit easier to get, but most of the programming will be in Portugese.
My blindscan for 65w:
'DVB-S2 8PSK 4510V / 2083 / 2/3' > Tp# 1
(1)TV Assembleia
'DVB-S2 8PSK 4555V / 2083 / 5/6' > Tp# 2
(2)NCN-RADIO 1 (Radio #1)
(3)NCN-RADIO3 (Radio #2)
(4)NCN-RADIO2 (Radio #3)
(5)HEVC Encoder1
(6)HEVC Encoder0
'DVB-S2 8PSK 4565H / 5083 / 3/4' > Tp# 3
(7)NOVO TEMPO 1-SEG
(8)NOVO TEMPO HD
'DVB-S2 8PSK 4577H / 3750 / 2/3' > Tp# 4
(9)Rede Familia 1Seg
(10)Rede Familia HD
'DVB-S2 8PSK 4607V / 3750 / 2/3' > Tp# 5
(11)ATALAIA_SAT
(12)XODO_FM (Radio #4)
'DVB-S2 8PSK 4613V / 6400 / 2/3' > Tp# 6
(13)RADIOUNAM
(14)CUAIEED
(15)TVUNAM
'DVB-S2 8PSK 4649H / 30001 / 5/6' > Tp# 7
'DVB-S2 8PSK 4687H / 3750 / 2/3' > Tp# 8
(16)4687H SID 0x01
(17)4687H SID 0x02
'DVB-S2 8PSK 4688V / 7074 / 3/4' > Tp# 9
(18)TV TEM HD
(19)TV TEM 1SEG
'DVB-S2 8PSK 4692H / 3720 / 3/4' > Tp# 10
(20)BAND TRIANGULO 1 SEG
(21)BAND TRIANGULO HD
'DVB-S2 8PSK 4697V / 7073 / 3/4' > Tp# 11
(22)TV TEM HD
(23)TV TEM 1SEG
'DVB-S2 8PSK 4698H / 6668 / 3/4' > Tp# 12
(24)TV INTEGRACAO
'DVB-S2 8PSK 4703H / 2500 / 2/3' > Tp# 13
(25)TV ALBA HD
(26)TV ALBA 1Seg
'DVB-S2 8PSK 4706V / 7074 / 3/4' > Tp# 14
(27)TV TEM HD
(28)TV TEM 1SEG
'DVB-S2 8PSK 4708H / 5000 / 3/4' > Tp# 15
(29)TRAS HD
'DVB-S2 8PSK 4720H / 10000 / 3/4' > Tp# 16
(30)Cultura FM (Radio #5)
(31)Radio Mix (Radio #6)
(32)TV INTEGRACAO UDI
(33)TV INTEGRACAO AXA
'DVB-S2 8PSK 4732H / 9167 / 3/4' > Tp# 17
(34)TVE MOBILE
(35)TVE HD
(36)EDUCA BAHIA
(37)EDUCADORA FM
(38)EMITEC 1
(39)EMITEC 2
(40)EMITEC 3
(1)TV Assembleia
(5)HEVC Encoder1
(6)HEVC Encoder0
(7)NOVO TEMPO 1-SEG
(8)NOVO TEMPO HD
(10)Rede Familia HD
(11)ATALAIA_SAT
(13)RADIOUNAM
(14)CUAIEED
(15)TVUNAM
(16)4687H SID 0x01
(17)4687H SID 0x02
(18)TV TEM HD
(19)TV TEM 1SEG
(22)TV TEM HD
(23)TV TEM 1SEG
(24)TV INTEGRACAO
(25)TV ALBA HD
(26)TV ALBA 1Seg
(27)TV TEM HD
(28)TV TEM 1SEG
(29)TRAS HD
(34)TVE MOBILE
(35)TVE HD
(36)EDUCA BAHIA
(37)EDUCADORA FM
(38)EMITEC 1
(39)EMITEC 2
(40)EMITEC 3
Just wondering - is this a typo ?, was not aware of any extended C-band on 61West
MrDish1
Delta Star
Qth:Aalten
How can I see in Lyngsat's list which or what is ;C-Band Extended
Best regards
Best regards
I can't find any dedicated page that just has a list of C-band Extended frequency satellites but the main two for domestic video content for me in the UK are 40.5W and 65W.
Lyngsat pages that show Extended C-band frequencies look like this as in pictures and the extended frequencies carry on from the highest last listed 'normal' Cband frequency ie: 4.2 GHz - as you can see, there are no Cband frequencies listed for 61West Lyngsat 61 West. No C-band listed..JPG65West. with extended C-band..JPG
Possibly not reported on Lyngsat by any DX Men.
The satellite sites like Lygnsat and Flysat are only as good as the users who upload info.
The same issue of missing frequencies also applies to some of the extreme East satellites such as 152E and 160E, these have more frequencies on them than are listed on Lyngsat.
Yep good point MB.... usually when i move from say 47.5W or 55W up to 65West iv'e got the Promax running on full scan display but can't ever remember seeing any Extended C-band signal spikes from 61W showing as i went past it to 65W - i'm double checking now :)
@John
The 61W C-Band beam covers the Americas.
I think that @el bandido is based over that way so will receive beam footprints that are probably not available to UK DX Men?
The other forum member who should be able to check 61.0W for extended C-Band is @frankviana I think he is located in Brazil and has a reet good set of dishes to check with.
Also, there is a member on Edgar's gaff who regularly posts feed details who is based in Paraguay, he might be able to check if he has an appropriate LNB?
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
Here is what I scanned a few minutes ago on 61w:
'DVB-S2 8PSK 3940V / 5000 / 3/4' > Tp# 1
(1)SBTRS_HD
(2)SBTRS_1SEG
'DVB-S2 8PSK 3959H / 3750 / 2/3' > Tp# 2
(3)ALTV
'DVB-S2 8PSK 3968H / 9875 / 2/3' > Tp# 3
(4)3968H SID 0x01
(5)3968H SID 0x02
(6)3968H SID 0x03
(7)3968H SID 0x04
(8)3968H SID 0x05
(9)3968H SID 0x06
(10)3968H SID 0x07
'DVB-S2 8PSK 3975H / 2500 / 2/3' > Tp# 4
(11)TV alesp
'DVB-S2 QPSK 3991H / 1667 / 4/5' > Tp# 5
(12)Telerama_Ecuador
'DVB-S 4013H / 27537 / AUTO' > Tp# 6
'DVB-S2 QPSK 4139H / 4543 / 3/4' > Tp# 7
(13)4139H SID 0x01
'DVB-S2 8PSK 4157H / 5600 / 2/3' > Tp# 8
(14)RPC HD
(15)UNICANAL HD
(16)GEN HD
'DVB-S2 QPSK 4173V / 2500 / 5/6' > Tp# 9
(17)ABC COLOR PY
'DVB-S 4178H / 2500 / 3/4' > Tp# 10
(18)TV Capixaba
'DVB-S2 8PSK 4535V / 4780 / 3/4' > Tp# 11
(19)VTV SBT 1SEG
(20)VTV SBT HD
'DVB-S2 8PSK 4558V / 3333 / 3/4' > Tp# 12
(21)WooHoo HD
'DVB-S 4707H / 34468 / AUTO' > Tp# 13
Manikm909
Small'ish Dish Man
Kent, UK
hey @John - does that mean i should be able to get some stuff at 65w - that HAS to be at the end of my range - but will try if so....deffo need to move jack to other side at this rate
To get the frequencies on 65.5W between 4.5-4.8 GHz you will need an LNB that can cover that range.
Manikm909
Small'ish Dish Man
Kent, UK
i probably have no chance then, considering the interference i get,
MrDish1
Delta Star
Qth:Aalten
Can a normal C-band lnb be changed to this frequency (4.5-4.8 Ghz)
Best regards
Manikm909
Small'ish Dish Man
Kent, UK
Cos of the 5g interference I get ...no? What lnb do I need for this range ?
You are getting 5G interference down in the 3400 - 3700 MHz range.
I dont see why this will interfere up in the 4500 to 4800 MHz range so you should not need a 5G filtering LNB.
There are also extended C-Band frequencies on 40.5W that are receivable at a UK location.
You need one of these Chinese bad boys pictured below or any alternative LNB that covers that range.
The LNB pictured below is the mini block WR229 flange type, it needs a cheepo Chinese horn pipe to bolt onto.
I got a box full of these Chinese bad boys for sale at huge wad, no bargains 'ere.
I think that there are also extended C-Band LNBF's available that you shove into a polo pipe or clamp directly into a feed holder.
In order to first get an idea of anything extended with your existing system, get a cheap terrestrial analyser and slave it onto the passive output (many two way splitters will kill off the DC on one side) of your current LNB.
Look for any spikes of reasonable levels between 350 and 650MHz as you scan around the arc.
