Advice Needed Corotor on a Offset dish?
cirio70
Laminas 180 - Fracarro UX-TW-LTE(PLL) - C Band - TBS6903 - Octagon SF 8008 -Zgemma H92S
Lombardy - Italy
Since I'm not completely satisfied with my C band installation (Usual double LNB out of primary focus) I was thinking to try to use a corotor on my laminas AS1800.
I searched on the net, but I can't find much information.
So I'm asking you guys, as long as I put a conical ring on the corotor, will it work on my offset dish. Signal loss on KU band will be too much?
(BTW, I soon will be a lucky owner of dreambox positioner, so yes, I will be able to control the corotor)
Thanks,
cirio70
Lombardy - Italy
You mean put C band in primary and Ku off focus?
I can try...
dreambox1959
46.3N-4.3E-FRANCE
france
or try to put an lnb changer !
my posi also manage this feature !!
JP
I can try...
A co-rotor has both Ku and C band at one focus.
Perhaps you have a bullseye ?
cirio70
Lombardy - Italy
I was refering to your reply : "Invert..."
I thought you meant 'invert the LNBs'.
Forgive me but as you can imagine english is not my mother-tongue so maybe i misunderstood what you said.
