55,5° West Intelsat 34
dreamsat
germany
i show you many Data channels
dreamsat
germany
my currend scan with 2,20m
dreamsat
germany
two s2X transponders with 2,20m
frankviana
Satellites/tv
Brazil
How to identify s2x transponders? Is there any comparison only with the FEC?
dreamsat
germany
not only other FEC but the FEC and the modulation are changed more often. I think the best way to do this is with the PC card.
frankviana
Satellites/tv
Brazil
Yes... I have TBS 6903X and 5520se, but It would be interesting to incorporate in some software the option to show s, s2 and s2x (ebspro, neumodvb, crazyscan, etc)
dreamsat
germany
For me this is the last western position with the 2.20m antenna.:cool:
i work with CrazyScan 1.0.2.171 and TBS 6903X
Manikm909
Small'ish Dish Man
Kent, UK
can you not get 58w ?
dreamsat
germany
not with the 2,20m antenna
dreamsat
germany
my scan
Manikm909
Small'ish Dish Man
Kent, UK
Yep, it's locked on the Promax at 11.2 - 11.6 dB max - i'll just scan it with the Combo and get back.
thanks! nice one.
btw, what promax do you own @John
The Combo didn't pick it up on a Blind Scan but did pick it up when entered details manually. Still waiting for the Poop to flow
Manikm909
Small'ish Dish Man
Kent, UK
interesting it didnt pick up - might be why i never saw it... thanks!
Interestingly though, the Promax, CS & EBSPro picked up and locked straight away
Manikm909
Small'ish Dish Man
Kent, UK
im thinking about putting my jack on the west side....as im hardly ever on EAST now - the jack will be stronger closed than extended, and i can be braver re having dish further west with jack closed \ on limit.
dreamsat
germany
my current scan in Ku-Band:cool:
