7E (Eutelsat 7B/7C)
That transponder used to come in quite well here in the Midlands, gone weak now. Screenshot_20230305-094934_Finder.jpg
OT: @scopus how are you finding the Dr. HD Finder?
Off all the fairly cheap speccies this is the best one I have used..You can bluetooth it to a phone for setting up or a tablet. I don't think the on screen cursor works above andriod 9 though..Moonbase will confirm that..
stel883_
"34.5W-70.5E - Gibertini OP125L, Actuator 18", Superjack 3618, Moteck Vbox2, IBU PLL Single, DM900 RC20 UHD 4K" "45W-70.5E - Gibertini OP100L, Moteck SG2100A, IBU Single, Edision OS Mini 4k" "Tivusat Gold Card & Cam" "Toshiba 32L3963DG"
"Fujitsu Lifebook S752 - Windows 10 64-bit"
Vátika, Greece
Hi, just for reference, here from southern peloponnese greece, on gibertini 1.25 and dm900.
Actually it was my Chinese tablet that had the issue with the finger slide movement of the cursor rather than the Android version. The Dr HD Finder app runs perfect on all other Android mobile devices I have tried.
It is not a big issue as you can still tap the screen to move the cursor bar along the spectrrum, it is just the finger sliding of it that is the issue and that is only on a cheap Chinese tablet.
Lexzie
TBS 5925 USB-tuner
The Netherlands
According to Lyngsat 11262 H, 11304 H, 11324 V, 11345 H and 11387 H are also on Europe B beam of Eutelsat 7B.
11262 H should be easier to catch, just 4.4 dB C/N for a lock, instead of 5.5 dB, because of the FEC of 2/3 (instead of 3/4).
Still the signal here is 0.75 dB weaker.
11304 H is only 0.5 dB weaker.
By the way, the footprint shown on Satbeams is a bit more positive for the UK (Southeast).
10991 V,22856,25/36,(S2x)/16APSK,0.05,HEVC 4.2.2.-UHD feed(still FTA)7.0E_
At the moment, this feed UHD-10991 V-is still FTA.
CPU is almost at 100%
10991 V,22856,25/36,(S2x)/16APSK,0.05,HEVC 4.2.2.-FTA
