Es'hail 2 25.8°E channels
dreamsat
germany
I watched the amateur radio band again today. With the online monitor you can easily track who and how many carriers are currently on the air.
another one
01. 10730H, SR30000 (El SharqTV)
02. 10730V, SR27500 (Al Rayyan)
03. 10770H, SR27500 (Alkass)
04. 10770V, SR27500 (Qatar TV)
05. 10850H, SR27500 (bein)
06. 10890H, SR27500 (bein)
07. 11310H, SR27500 (bein)
08. 11350V, SR27500 (bein - new upload)
09. 11390H, SR27500 (bein)
10. 11430V, SR27500 (bein)
Clean slate here too. You're right about 11350V - I had to click it a couple of times to get maximum signal but all scanned in from one location.
Sod all from Es'Hail1 though barring a few blips.
The Al Jazeera frequency from Es'hail-1 at 25.5 East is the easiest to lock, it is locked stable 24/7 whenever I put the dish on it.
The bein's from 25.5 East are a bitch to lock as they seem to fluctuate in signal level over the course of a day. I can lock two or three of them at times but the others are a lost cause.
Due to the marginal threshold I have with those bein's, the only receiver I have managed to lock them with is the Dr HD F15.
None of the Poop pourers can lock them as their tuners are not as good as that of the F15.
Which Al Jazeera frequency as there are two of them?
I am guessing it's the 11604H one as it's DVB-S.
Yes, it is the 11604H Al Jazeera from 25.5 East that I can lock 24/7.
The other Al Jazeera on 11046H is around 1.7dB below a lock, hovering around 4.8dB to 4.9dB and needing 6.6dB theoretically.
Yeah, nothing but a few flickers of signal on 11604H frequency. Never had a chance of this satellite here.
stephan94
Bavaria
It is true that from your reception place you need a very big antenna to receive this frequency.
With an antenna of 1,80 from the north of Bavaria, so further south than you I can see this transponder
with only 6,2dB (the weather is bad at the moment with a little snow)
suedschwede
2.7m Laminas+Polarmount+JPC-Posi+SF8008
DE
No problem here either :)
suedschwede
DE
Actual CrazyScan
anto@
italy
test reception 26 east extended band
test carried out with 2000s lnb and 80 cm disc
dreamsat
germany
Getting back to the original topic of the Es'hail 2 Reception. This is how it currently looks here.
Reception and decode of H266 VVC video on QO100 SR125 using VVC Easy.
 https://github.com/MartinEesmaa/VVCEasy/blob/master/MPV.md
To decode the video create a shortcut to VVCEasy exe file, right click it, choose properties and then add the UDP address to the end of the target line after the quotation marks.
dreamsat
germany
10955 H 790 DVBS2/8PSK 3/4
5 Radiostations without identification.
it could also be from Badr 7. is difficult to separate.
danny10
Amiko Alien 2,E - 85,Famaval 110 ,IBU twin
Czech republik
Radios are already in transponder 10970 H NW Africa Badr 7..
dreamsat
germany
today i have reception at 10730 H 30000 DVBS/QPSK 3/4
dreamsat
germany
very close 10850 H 27500 8PSK 2/3
dreamsat
germany
in the night is much better
ocean04
Vaasa
Western Finland (63N 22E)
10730H 5.8db
10730V 8.0db
10770H -
10770V -
10810H 7.2db
10810V 7.2db
10850H 7.8db
10850V 6.8db
10890H 7.8db
11310H -
11310V -
11350V -
11390H -
11390V -
11430V -
Used to receive 11350H when it had easier fec. Signal was around 5db then
dreamsat
germany
I've never had any success vertically in the lower range.
ocean04
Vaasa
I see in post #51 you have lock 11310-11430. Not sure why these are weak here, but 10730-10890 signal is better.
