Amos 7 (was Asiasat 8) 4W
Satfaca
Melmac (46N, 14.5E)
Melmac
Can anyone find anything useful in this stream? It is on the european beam so anyone can receive it here.
dreamsat
germany
my reception today
dreamsat
germany
The values on 11035 H were not that good for a long time. Despite the rainy weather, the signal is stronger than usual.
Scan in vertical
I have 3 frequencies from the Middle East beam of Amos 7 at 3.9W locking at the moment.
There might be another one locking later if the signal level improves towards evening or the weather improves.
The 3 locked frequencies are:
1. 11047H, SR5000 @ 8.8db
2. 11062H, SR4500 @ 6.8dB
3. 11069H, SR3702 @ 5.4dB
A few screenshots of the locked frequencies are attached below.
03.9W_Amos7_ME_Beam_11047H_SR5000.jpg 03.9W_Amos7_ME_Beam_11062H_SR4500.jpg 03.9W_Amos7_ME_Beam_11069H_SR3702.jpg
11100 H,12000,3/4,32APSK-GS (@dreamsat on FlySat)
The other frequency that I had hopes of locking from the Middle East beam of Amos 7 at 3.9W is now locked.
The improved weather with clear skies this morning allowed 11035H, SR6083 to be locked, list updated below.
The 4 locked frequencies are:
1. 11035H, SR6083 @ 7.3dB - new upload
2. 11047H, SR5000 @ 8.8dB
3. 11062H, SR4500 @ 6.8dB
4. 11069H, SR3702 @ 5.4dB
A screenshot of the newly locked frequency is attached below.
Note:- Please ignore the date/time shown in the screenshot. The receiver became unresponsive yesterday and I had to reset it, the date/time still needs to be updated. The screenshot was taken this morning.
wellikan
satdx.club
Dr.HD 1000 Combo, Denys H.265, TBS 6903
GIBERTINI OP 150 S
Ireland
I can say with confidence that in the west of Ireland, except for the satellite AMOS 3_ Europe Vertical pol. Beam can't capture anything
Signal levels seem to be stronger today from Amos 7 at 3.9W.
I have attached a few screen grabs below showing the increased levels
The 4 frequencies locked to data are:
1. 11035H, SR6083 @ 7.3dB (no change)
2. 11047H, SR5000 @ 10.7dB ( up from 8.8dB )
3. 11062H, SR4500 @ 7.0dB ( up from 6.8dB )
4. 11069H, SR3702 @ 6.1dB ( up from 5.4dB )
03.9W_Amos7_ME_Beam_11047H_SR5000_v2.jpg 03.9W_Amos7_ME_Beam_11062H_SR4500_v2.jpg 03.9W_Amos7_ME_Beam_11069H_SR3702_v2.jpg
The only lockable frequency for me is 11062, owing to its forgiving parameters. The other are all under lock (but not by much). It is very wet and windy here though.
Did you ever manage to get any Yes frequencies?
I have not had any sightings with reasonable signal level for any of the "Yes" frequencies.
The Dr HD F15 receiver is getting a very low signal level on a few of them but I am not sure if it is bleed over from 5.0W.
I need to match up the frequencies I am getting to check if there is anything similar on 5.0W, unfortunately, I have not got around to that yet.
Once I have checked them out against 5.0W I will post a few screen grabs if they are "potentials"
ocean04
Vaasa
Western Finland (63N 22E)
For comparison, currently only 11080V not working here. 3m + SF8008
10972V 8.0db
10998V 6.8db
11030V 6.8db
11035H 8.8db
11047H 13.0db
11058V 8.0db
11061H 9.5db
11069H 9.0db
11080V -
11103V 9.5db
11474V 7.8db
11501V 5.5db
Satfaca
Melmac (46N, 14.5E)
Melmac
After 11.501 V has been switched off now 11.473 V delivers around 3 dB more so worth a try...
dreamsat
germany
After switching off some vertical transponders, all of the Middle East beam is now also possible vertically.
dreamsat
germany
Vertical plane transponders are back
dreamsat
germany
today a good reception at 4,0° West
dreamsat
germany
in the evening is signal better
dreamsat
germany
Despite the rainy weather, the signal has once again increased significantly.:Y
dreamsat
germany
11074 H 499 DATA
11065 H,1100,1/2,S2-GS, (not new,@dreamsat above)
The signal has dropped on 4.0W since some muxes were moved to other carriers. Now the strongest is on this mux, 11065 H.
