- Jan 1, 2000
- Age
- 81
- The Flatlands of East Anglia
si2183 chip and av201x chip info was found in the logfile.You have two dashes missing in the command.
In the mean time I doubkle checked the spectrum of tbs6504, which uses the same code. There are no spurious peaks there.
What you need to is report the lines in the kernel log which show the models of teh si2183 chip and av201x chip
Sorted out my correct commands, built neumo-blindscan for TBS6522 verticals on 27.5W. Drew a chart.
Horror of horrors, it's plagued with 50 MHz spikes
I'll do a Horizontal in due course to see if it displays similar effects.
