New DAB mux @ 9 East
cirio70
Laminas 180 - Fracarro UX-TW-LTE(PLL) - C Band - TBS6903 - Octagon SF 8008 -Zgemma H92S
Lombardy - Italy
A new DAB mux appeared on 9 east. Unfortunately is on the italian beam so not for everybody, and it's a multistream frequency.
9 East
12149 V 31400 16APSK Stream 101 and 102
(PLS: 262140)
It's a test for a Tuscany DAB mux. ATM only a station is broadcasted (Radio Firenze on Channels 1 to 6, channels 7 to 12 are mute)
The command for eti-tools is:
wget <IP>:<PORT> -q -O | tsniv2ni 7030 2>\dev\null | dablin_gtk
cirio70
Lombardy - Italy
The tests are going on today:
On both streams we ave
1 to 5 Radio105
6 to 10 Radio 101
11-12 Mute
i've been told the command i posted is wrong...:-doh
Right command is :
wget <IP>:<PORT> -q -O | tsniv2ni 7030 2> /dev/null | dablin_gtk
Salvuccio9239
Dish 100 cm, 11 feed.
Palermo, Italy
Ciao Cirio, allora ho installato i file su usr/lib e anche su usr/bin. Ma quando vado a dare il comando per far partire dabstreamer mi da questo errore "cannot execute: required file not found" e poi un altro passaggio che non capisco è come creare il settings con i servizi radio, a me interessano il nuovo mux ITEL, EuroDab e DAB Italia. Grazie!
Si prega di tradurre i messaggi in inglese
Hi Cirio, so I installed the files on usr/lib and also on usr/bin. But when I go to give the command to start dabstreamer it gives me this error "cannot execute: required file not found" and then another step that I don't understand is how to create the settings with the radio services, I'm interested in the new ITEL mux, EuroDab and DAB Italy. Thank you!
cirio70
Lombardy - Italy
Please, be patient :cool:, i will translate the guide in the italian forum later this evening.
Sorry guys for the little OT.:)
porta pazienza, in serata tradurrò la guida sul forum italiano,
Ciao
Salvuccio9239
Palermo, Italy
Ciao
Thank you!
Satfaca
Melmac (46N, 14.5E)
Melmac
Thanks to cirio70 ... already playing trough the box.
andimik
120cm with Stab rotor, TBS 5927 and 6903xv1
Southern Austria
Can you confirm if the labels are correct? I don't believe that.
Or did you modify the config by mistake???
If yes, please remove that screenshot, otherwise it's a fake.
EnoSat
enosat.euweb.cz
Slovakia
andimik
Southern Austria
I know of course, I am contributing to the eti-tools and so on.
I just want to avoid fake screenshots, because the labels are self made.
Have tested these 101 and 102 yesterday, but all comments the Mux is for Tuscany is not true, because the content doesn't exist on DAB there. The sat feeds we are talking about are tests only (so far).
Satfaca
Melmac (46N, 14.5E)
Melmac
If you're asking me, yes, the labels are correct ... beacuse those are the stations airing there. These are of course labels named by hand in the Dreamboxedit. or how else do you expect to have them named like that on the receiver's list?!
If you doubt this is for Tuscany, then you have to discuss with cirio70, he's from Italy ... I suppose he knows better.
andimik
Southern Austria
I can speak Italian, too. My village is just 3 km away from the border and I know the Italian radio landscape.
Please remove all self made screenshot with fake labels from this forum.
Satfaca
Melmac (46N, 14.5E)
Melmac
It appears you joined this forum for a very particular reason. :confused
andimik
Southern Austria
Well, I try to ask you again to remove this fake screenshot. This is NOT Tuscany DAB!
cirio70
Lombardy - Italy
Just to be clear, this is what is broadcast on Stream 101 PID 7030:
root@sf8008:~# wget 127.0.0.1:8001/1:0:1:1:1:2:5A0000:0:0:0 -q -O- | tsniv2ni 7030 | ni2out --list
Ensemble:  (0x5000)
 #  Programme Label   Serv.Id.  P/S SubCh Capac.Units   Prot.   Bitrate Mode
 1: Channel1          (0x5001)  Prm   1   72 (  0- 71)  eep-3a  96 Kb/s DAB+
 2: Channel2          (0x5002)  Prm   2   72 ( 72-143)  eep-3a  96 Kb/s DAB+
 3: Channel3          (0x5003)  Prm   3   72 (144-215)  eep-3a  96 Kb/s DAB+
 4: Channel4          (0x5004)  Prm   4   72 (216-287)  eep-3a  96 Kb/s DAB+
 5: Channel5          (0x5005)  Prm   5   72 (288-359)  eep-3a  96 Kb/s DAB+
 6: Channel6          (0x5006)  Prm   6   72 (360-431)  eep-3a  96 Kb/s DAB+
 7: Channel7          (0x5007)  Prm   7   72 (432-503)  eep-3a  96 Kb/s DAB+
 8: Channel8          (0x5008)  Prm   8   72 (504-575)  eep-3a  96 Kb/s DAB+
 9: Channel9          (0x5009)  Prm   9   72 (576-647)  eep-3a  96 Kb/s DAB+
10: Channel10         (0x5010)  Prm  10   72 (648-719)  eep-3a  96 Kb/s DAB+
11: Channel11         (0x5011)  Prm  11   72 (720-791)  eep-3a  96 Kb/s DAB+
12: Channel12         (0x5012)  Prm  12   72 (792-863)  eep-3a  96 Kb/s DAB+
Free CUs on this multiplex =   0
Like yesterday:
1-5 : Radio 105
6-10 : R101
11-12: mute
As i said privately to Andimik i assumed a test for Tuscany 'cause in the early days Radio Firenze (Florence which is in Tuscany) was transmitted.
ATM two national radios are transmitted so i'm not sure this will be a Tuscan Mux.
Anyway the ensemble is labeled "IDMUX-ITEL-TEST" so it's a test...:cool:
andimik
Southern Austria
Thanks for the reply. Yes, currently we don't know the reason for the lab generated muxes.
Due to the fact that in Tuscany there are already several muxes running on various sites (I was there in April and have investigated all of them, incl. new TII codes for FMLIST) I also expect one or even two new Mux(es) after (!) the current tests.
EnoSat
enosat.euweb.cz
Slovakia
Eid 0x5000 has not yet been used in terrestrial broadcasting (at least according to fmlist.org)
Satfaca
Melmac (46N, 14.5E)
Melmac
Would this one make you feel good?
humaxboy1
Gibertini 125 cm 75°E-45°W
ClarkTech Diseqc HH390 Prolong arm
Inverto Black (white) Ultra Single LNB
Octagon SF 4008
Slovenia
Stream 101 is gone ? I can't scan anything atm, yesterday evening it was there...
Satfaca
Melmac (46N, 14.5E)
Melmac
Hm, strange indeed. Stream still there, with all same parameters ... just no sound can be heard.
