NFL International 19.2°e
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Has anyone had any success receiving NFL International at 19.2°e?
No luck for my with my zone 2, sf8008.
The report from KoS is 2 days old and it may be a temporary feed?
Maybe the report was logged at the wrong satellite position.
11817.00VDVB-S216APSK31428 4/5
Dave5118
1.5m Gibertini with Inverto 5434 Unicable Hybrid LNB.
TBS 6903 with EBSPro
Vu+ Uno 4K SE
Edision OS Nino Pro
Starsat 2000HD Hyper
Sky Q Silver
Sky minidish with Sky Q Hybrid LNB
Nr Manchester UK
Yeah, they are there 4 channels, all showing the same content though. NFL 2.jpg
statalite
Zone 1 @ 28.2°E
SMR 1224
UK Midlands
Dave5118
Vu+ Uno 4K SE
Edision OS Nino Pro
Sky Q Silver
Nr Manchester UK
Yeah, but seems as strong as the other TXs, but I'm guessing the 16apsk modulation will cause problems for smaller dishes. I may be wrong.
EnoSat
enosat.euweb.cz
Slovakia
Modulation is a problem only for very old receivers, a bigger problem is the processing of the 100Mbit/s transponder data stream in the demodulators of the receivers.
You need a signal above 11dB to lock this mux.
EnoSat
enosat.euweb.cz
Slovakia
It should be no problem to reach 11dB in the UK Midlands on your Channel Master 1.2m
satellites.xml should contain
<transponder frequency="11817000" symbol_rate="31429000" polarization="1" fec_inner="8" system="1" modulation="4"/>
or (if the image does not support defining 16APSK)
<transponder frequency="11817000" symbol_rate="31429000" polarization="1" fec_inner="0" system="1" modulation="0"/>
MCelliotG
Thessaloniki, Greece
No problem with my HD51. Just input 8PSK instead of 16APSK (known driver issue) and FEC to Auto.
EnoSat
enosat.euweb.cz
Slovakia
Yes, HD51 work only with modulation - 0,1,2
Beli1910
Sevnica-Slovenija
Wave frontier t90 45E-5W
Triax 110-,motor
Laminas 1.8m and Laminas 120
Chanel master 125
Gibertini 150 fix
Gibertini 125
Etc....
Sevnica 8290-Slovenija
on Edison os mio 4k plus works on the parameters that are written on the web pages. Location Sevnica Slovenia-antenna gibertini 150.
EnoSat
enosat.euweb.cz
Slovakia
Edision works in Auto mode, it will accept whatever you enter
stephan94
Bavaria
with the Openbox S3 Mini II HD no Problem
Encode_1080P_19.mp4_20230818_124855.803.jpgEncode_1080P_19.mp4_20230818_124949.755.jpg
ViaHussun
150 cm offset Gibertini antenna
Inverto Premium Twin LNB
TBS 5520SE TV Card
Bursa , TURKEY
12,5 dB
ViaHussun
TBS 5520SE TV Card
Bursa , TURKEY
19E 11817 V 31428 16APSK 4:2:0
NFL MUX test
Premier League
FTA :-biglaugh
anto@
italy
Il mio segnale
  • 2023-08-18 20_52_07-2023-08-17 21_16_15-(5) Libero Mail - Posta.png ‎- Foto.png
