Listen Up France 2 in UHD ?
MCelliotG
Thessaloniki, Greece
I don't have time to do it myself, but perhaps astra-sm could do its magic?
EnoSat
enosat.euweb.cz
Slovakia
Astra-SM is not required
MCelliotG
For the DVB-T part I mean!
EnoSat
enosat.euweb.cz
Slovakia
It is useless, since the signal comes as DVB-S and we will not convert it into a stream for a DVB-T transmitter with our HW.
The professional HW on the DVB-T transmitter will just ignore the pids intended for DVB-S. As now the pids for DVB-T are ignored in our boxes.
Anyone who wants to can use TSDuck and change the identification pids and create a stream for a DVB-T transmitter.
Adam792
Cheltenham
Sadly not :( The DVB-SIS system includes using the same video and audio streams (there's no second tunnelled version of the channels themselves - just the separate table data) - the system handles decryption, so the hardware will process the Viaccess before assembling a DVB-T2 mux from the metadata at each transmitter site.
MCelliotG
PID 8191 looks like an encapsulated stream, where the non-encrypted UHD streams should be. There would be no logic to transmit the channels encrypted in Viaccess terrestrially.
Adam792
Cheltenham
That's the null packets PID sadly. :(
They won't transmit in Viaccess terrestrially, the DVB-SIS hardware at the transmitter sites will first decrypt the Viaccess, then re-assemble the decrypted PES along with the separate table data into a local T2-MI stream for terrestrial modulation, the encryption data is discarded.
Here's a description of the system as being used in Thailand - Analog to digital television transition with single illumination Thai-PRD
There the channels are encrypted with BISS, and the DVB-SIS hardware descrambles them before creating the T2 multiplex from the descrambled data. (This is probably using 78.5°E C band)
EnoSat
enosat.euweb.cz
Slovakia
MUX3 use partial-encrypt :ph34r:
MCelliotG
That's different, it's a paytv package. Are there plans for the UHD channels to be pay tv?
EnoSat
enosat.euweb.cz
Slovakia
If they will be there under public, they should be FTA, if they will be there commercially, it is difficult to predict.
MCelliotG
So, our fear is that all FTA multistream packages will be encrypted to Viaccess and move to DVB-SIS, so no FTA French TV anymore, and no way to descramble.
EnoSat
enosat.euweb.cz
Slovakia
Sad John Cena GIF
Adam792
Cheltenham
I think in this case one of the driving issues must be Eutelsat 5WB with its fault meaning that its capacity has always been very limited. In NW Europe we’ve already lost a lot of the free Italian TV because of this after it moved to the 9°E Italian beam.
It’s desirable for them to have a solution where they only need a single transponder to feed both Fransat subscribers (with Viaccess) and the terrestrial transmitters that will transmit the DVB-T2 version (without encryption).
The cost saving of one transponder rather than two probably compensates for the extra costs of DVB-SIS and descrambling equipment needed at each terrestrial transmitter site sadly :( Hopefully the other stuff won’t change, I’m hopeful because there are lots of DVB-T transmitters that would need upgrading, whereas this new DVB-T2 multiplex is an entirely new deployment, allowing them to use this new method more easily.
stpierre
Multisat Indoor Home Made 10 LNB 52°e > 5°w + Fibo 90cm USALS = 68°e > 45°w
Belgium
Scan today, "Test HD" sometime FTA !
No more UHD channels viewables !
tompouce
1.2 M Channel Master motorized+ Gibertini 150 C-band fixed + TBS 5925/6983+ Octagon SF4008
Belgium
stpierre
Belgium
Thanks tompouce, I saw that !
SimonE
Gloucestershire, UK
12522V SID 1804 is now carrying TV5 World in HD. Your Fransat cam and card will be needed/
stpierre
Belgium
Some news !
EnoSat
enosat.euweb.cz
Slovakia
none news
#post19 show DVB-SIS (DVB-S and DVB-T in one stream)
