TM-5402 HD M3 - all BBC channels missing after factory reset
zamperoni
Technomate TM 5402 M3
Edinburgh
I did a factory reset on the box after some channels went missing e.g. BBC FOUR
Now there are no BBC channels appearing in the channel list on ASTRA 2/EUROBIRD - though all the german channels are still present
I've tried "adding TP" by pressing green button on Advanced Search and entering Frequency 10773 and Symbol Rate 23000 then scanning but still no BBC channels appearing
There should be no German on the 28.2E satellite.
rodscha
you are receiving Astra 1 on19E instead,and yes,lots of German channels!
so you need to re-align on to 28.2E
zamperoni
Edinburgh
Yes you're quite right, I didn't realise that before. Anyway that helped me to understand the problem.
After doing a factory reset (for the first time since a professional installation) I didn't know I also needed to configure the Disecq settings. I ended up with only Astra1 19.2E channels but they were all listed as being on Astra2 28.2E.
Everything is ok now.
manic01
TM5402 mk1/2/3/4 TM1500 TM Mini various TM Nano various TM600 TM F3/5 TM Twin etc etc TD110
GB
Always keep a recent channel list backed up on usb stick, then can easily reload all channels
purplemarina
2x 1.2m motorised channelmasters . tm 5302, tm6902,
hampshire uk.
A blind scan will help you create an up to date channel list which you can save.
manic01
GB
