uktvplay.co.uk
Say42
Humax Freesat box + fibre
Lyon, France
As my satellite reception is poor, I have switched to using a PC to watch UKTVPLAY but something has changed recently and whilst I can watch a program, I cannot pause it or move through the timeline, am sure I used to be able to do this. Same behaviour on both Firefox and Edge. PC is running Win11. Channel4 site doesn't have the same issue
Has anyone else had the same problem and found a solution?
LeBelge
2x Triax TD 110, 2x Edision OS Mio 4K (plus), Edision OS Mini 4K, Edision OS Nino Pro
Belguim
UKTV Play is restricted to the UK, so you can't watch us anywhere else.
Say42
Lyon, France
Watching the program is not the problem, what I can no longer do is to is to fast forward/rewind.
astra19
98cm motorised technomate. 50e to 34.5w
Europe
Do you have any ad or content blockers enabled?
Do you have the same problem with iPlayer or ITV-X?
Say42
Lyon, France
Starting Firefox in Safe Mode (with all Add-Ons disabled) doesn't change anything.
LeBelge
Belguim
I use an USB stick to coppy to RAM PCLinuxOS
then I install in Firefox a VPN exstention in order to be able to watch Channel4.
The VPN has a blocker itself so I have to disable it before whatching.
PCLinuxOS is never installed on HDD in my computer.
I have a switch that turns off the 2 SSDs for Windows 11 & Xubuntu when I coppy to RAM PCLinuxOS.
That way I always have a virgin version of Firefox + VPN for streaming from ITV, BBC, Channel4 etc.
Before I used to have problems with 1tv.ru which always told me that I didn't turn off the ad blocker, until I started using PCLinuxOS copied to RAM.
