sophie101
- Apr 20, 2015
* Currently
1 x off set 60cm for 28.2e
1 x 60cm for 5w + 13e + 19.2e
Quad LNBs on each sent to different receivers in different flats.
- belgium
That's weird.lets not get the problem mixed up!
signal is there, for a day or so on TunerA - lets say hotbird at 16db on RAI1 - TunerB on 28.2e - all good for maybe 24 hours
then when i come back, TunerA reports 0% signal, TunerB - fine....
only a reboot brings back RAI1 on TunerA
I am only using tuner A and the dvb-t. I might not see the same problem but I will bear it in mind in case it happens, and then let you know.
