Advice Needed Receivers with the lowest Symbol Rate?
frankviana
Satellites/tv
Brazil
SF 8008 tune and lock SR 480
osmini4k, no signal:
I think limit for osmini4k is until SR 500
MCelliotG
Thessaloniki, Greece
Anyhow this is better than before. How about the radio IP feeds on 30W?
Is there a possibility of integrating these driver modifications into a downloadable image for the Edision OS MIO?
ocean04
Vaasa
Western Finland (63N 22E)
Today traveled to my "summer cottage" where I have Vu+ Zero 4K. Quite a lot of snow here in Finland btw.
Took me only about 5 minutes to patch the driver binary for 10492H and it's working. Interesting because Vu+ Zero4k has Silabs tuner.
But I guess it's the same as Vu+ Uno4K, this device has problem with low symbolrate.
MCelliotG
And a silabs tuner where they deactivated the SNR in db. Their psychotic mentality....
stephan94
Bavaria
The Ocean 04 improvements work perfectly with the TNAP-5 image from El bandido
with a universal LNB 10492 is received,
non-locked signals are indicated
SRs below 1000 are now received (I don't yet know where the lower limit is, maybe 500)
@stephan94
Is that the default skin from the TNAP image that you are using in the 10492 H screen capture?
Or is it another skin?
Thank you.
suedschwede
2.7m Laminas+Polarmount+JPC-Posi+SF8008
DE
Patches at #274, 10494 i haf no test with SF8008 make.
stephan94
Bavaria
@stephan94
Thank you.
No, it is CinoGriPLi modified a bit
EnoSat
enosat.euweb.cz
Slovakia
Test in EDISION OSmio+ 4K:
Original KO from TNAP ( SR-718 ok , SR-512 no)
Original KO from OpenViX (SR-718 no , SR-512 no)
Patch from 24.12 (SR-718 ok , SR-512 no)
Patch from 26.12 (show lock, but it is the previous transponder)
Patch from 27.12 (show lock, but it is the previous transponder)
Patch from 27.12 (SR-718 ok , SR-512 no)
stephan94
Bavaria
a record; a frequency with an sr of 500 has been locked (amateur radio)
ocean04
Vaasa
e2_changes_20231223.diff getestet im OpenATV7.4 with SF8008, Signal just above zero is displayed :)
Does that really work in SF8008 and OpenATV? Have you tested other transponders? In OpenVix SF8008 I'm getting nothing
MCelliotG
Damn, I only have my Mutant HD51 with me at my hometown... I really wanna see these differences.
Did Stephan mentioned that 10492 is now received with a regular LNB? Did I read correctly?
ocean04
Vaasa
Yes, possible with Edision + avl6261. What are the models using this tuner?
10492H also works with Vu+uno4k and Vu+zero4k using patched driver binary. I assume it's possible to patch all Vu+ 4K models.
So far unable to get it working in sf4008, sf8008, gbtrio, (these are all models I currently have)
humaxboy1
Gibertini 125 cm 75°E-45°W
ClarkTech Diseqc HH390 Prolong arm
Inverto Black (white) Ultra Single LNB
Octagon SF 4008
Slovenia
@ocean04 - is it possible to do "patching" for non-locked signals indication for sf4008 ?
Patches at #274 post are propably just for sf8008 ? Do I understand that you have to change only a few lines in 2 files or you have to build the whole image in linux env from the scratch?
