Advice Needed Receivers with the lowest Symbol Rate?
suedschwede
2.7m Laminas+Polarmount+JPC-Posi+SF8008
DE
e2_changes_*.diff.txt is for minimum reception when there is already a very low signal, for this, enigma² or the image must be rebuilt and is for all boxes.
avl6261_*.diff.txt is only intended for the Mio4k tuner driver.
My Testbuild.
jsda30
edision os mio 4k
spain
My Testbuild.
will be great if u finally build for sf8008 for get 10494 tps at 26e
tomorrow ill check with tnpa-5 image with edision os mio
suedschwede
DE
There will be nothing for the SF8008, the drivers are closed source.
For this purpose, a converted LNB and an LNB-LOF that has been offset in the settings must be used.
7mdish
Milan, Italy
I have Dreambox DM920. Interesting in 10494 transponder and SNR below lock threshold.
Is it possible to add these features in my box? Which image? Which patch?
Please guide me, my linux skill is very very poor. Thanks.
jsda30
edision os mio 4k
spain
My Testbuild.
where can be place the e2 changes diff file on box?
EnoSat
enosat.euweb.cz
Slovakia
nowhere, that's a description of the changes in the source code compilation
jsda30
edision os mio 4k
spain
i was testing with edision os mio 4k and tnpa-5 image and not get the 10492 tps at 26e
for me not work... i have a 90 cm dish here in canary islands!!
EnoSat
enosat.euweb.cz
Slovakia
in addition to support in the image, you also need an LNB ( if you are trying to use a Universal LNB ) that still partially works outside the specified band (ie the output filter does not suppress frequencies below 950 MHz)
stephan94
Bavaria
jsda30 wrote that he had an Inverto black ultra ( post 287) it must work
suedschwede
DE
@jsda30
I use this LNB
  • Bullseye Ultra High Stability Single LNB for QO-100, 2ppm TCXO
  • Single output
  • PLL synthesised design with 2 PPM TCXO
  • Factory calibrated to within 1 kHz
  • 25MHz reference output
  • Universal 40mm LNB fixing
  • Reception range 10.489 - 12.75 GHz
  • L.O. frequency, low band 9.75 GHz
  • L.O. frequency, high band 10.6 GHz
  • IF output, low band 739 - 1950 MHz
  • IF output, high band 1100 - 2150 MHz
  • LO frequency stability at 23C +/- 10 kHz
  • LO frequency stability -20 to 60C +/- 30 kHz
  • Noise figure 0.5 dB
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
Hi
The TNAP image that you downloaded was not designed to work in extended frequencies. Do the following if you want it to work:
(1) Do an online update (Main menu--->Setup---> Software update)
(2) Go to Plugins and select Download Plugins (Main menu--->Plugins, then press green remote button)
(3) Navigate to extra plugins and pres the OK button on the remote to enter. Select and install enigma2-plugin-extra-avl6261-t2mi-700mhz-europe_5.15.0
TNAP images are designed for use in North America, but it is also a DX'er type image. Transponder spacing has been eliminated in enigma2 and the blindscan plugin. Most of the filters and frequency checks or comparisons have also been removed. Edision receivers were put together well enough that you don't need these items.
TNAP Feeds were updated early this morning. The Edision MIO4K, MIO4K Plus, and the Mini4K will have the capability mentioned above. Thanks to ocean04 for getting all of this started!
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
Also,
More modifications were added so blindscan would work on finding transponders below 1000SR. The enigma2-plugin-extra-avl6261-t2mi-700mhz-europe_5.15.0 plugin should have the changes shown in the attached patch file. TNAP images makes a report after every scan and installs it in /tmp of receiver files.
You may also put a folder on usb drive named ServiceScan to get these reports on usb. A scan report of 117w c band is attached and shows found transponders down to 675SR. This scan was done using the Europe plugin.
Ku Blindscan is slow and seems to be somewhat corrupted. But it does work. The Ku blindscan works much better when the frequency range is not extended. The enigma2-plugin-extra-t2mi-module-tnap-mod_5.15.0 Does Not have extended frequency and works better on Ku blindscasn.
  • avl6261-low-symbol-rate-Europe.zip
  • 117.1W_C-band_218ch_63tp_01-01-2024_11-05-07.zip
stephan94
Bavaria
here the result of a blindscan which found a tranponder of sr 940 ( 23,5 East)
7mdish
Milan, Italy
No chance with my DM920?
jsda30
edision os mio 4k
spain
Also,
hi bandido happy new year
thanks for your support and great job
i done a update software
i installed the plugin extra t2mi module
but not get the 10492 tp at 26e
maybe i need a special lnb.. now i have inverto ultra black lnb....
or ill must to install this: avl6261-low-symbol-rate-Europe.patch
now im remember that i didnt get 755 permission :(
where its locate at box the file... for give permission¿
stephan94
Bavaria
You must install avl6261-low-symbol-rate-Europe.plugin otherwise it will not work
but first you need to uninstall the extra t2mi module plugin which is not for europe.
with the LNB that you have 10492 works without problem
jsda30
edision os mio 4k
spain
thanks for your replay stephan
avl6261-low-symbol-rate-Europe.plugin are on image repository.... isnt it? or get the file at post number 274
stephan94
Bavaria
@jsda30 :
Do as el bandido indicated in post 331,
we must not complicate what is simple.
suedschwede
DE
It is 4x the tuner driver with different features and functionality, I just looked at it.
