Advice Needed Receivers with the lowest Symbol Rate?
stephan94
Bavaria
@jsda30
can you show me a screenshot of "delete plugin" in "extra"?
you must have this (image)
stephan94
Bavaria
jsda30
edision os mio 4k
spain
screenshot_20240102154647.jpgscreenshot_20240102154819.jpgscreenshot_20240102155115.jpg
works for SR under 1000 but for tp 10492 at 26 not work
stephan94
Bavaria
Maybe the LNB you have is limited ,
but it's strange because with an Inverto Black ultra LNB (twin) it works for me.
stephan94
Bavaria
here is the T2MI search result in blindscan with the plugin "avl6261-t2mi-700mhz-europe (5.15.0)".
everything works perfectly ( satellite 40° East)
stephan94
Bavaria
did u see my lnb?
Yes, I did see your LNB.
It's possible that it's coming from this LNB, mine's a twin.
Do you have another LNB to try?
For me, the BEST HD3D 202 LNB also works perfectly.
It would be nice to be able to try with another LNB.
tompouce
1.2 M Channel Master motorized+ Gibertini 150 C-band fixed + TBS 5925/6983+ Octagon SF4008
Belgium
stephan94
Bavaria
Hello Stephan,
I'm still happy with my old SF4008. For ex., it works very good with the SR 543; on Eut 5WB, 11453H 1/2 Qpsk, french radios ; locked with 12.20 dB (snowy day) :)
Hello tompouce
the 4008 was (is) a very good receiver which unfortunately was abandoned far too quickly by the brand for very obscure reasons (the story is known by many people) happy new year to you
humaxboy1
Gibertini 125 cm 75°E-45°W
ClarkTech Diseqc HH390 Prolong arm
Inverto Black (white) Ultra Single LNB
Octagon SF 4008
Slovenia
I am also happy with my old SF4008. As mentioned by tompouce last drivers supports SR around 500, with old drivers not a problem even with SR 256 (scan + listen). "Old drivers" also see SR 186 for example on 30W but I can't scan it. See pictures attachment. SF8008 is still the best STB for low SR.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
.................."SF8008 is still the best STB for low SR".
Thanks, ¿what image version of open ATV allows an SR value of below 1000 to be entered?.........from memory the range was 1000 min to 60000 max. Perhaps amended driver config needed..........appreciated :Y
MCelliotG
Thessaloniki, Greece
In manual search you can enter whatever value you need, the 1000 limitation is for the blindscan plugin settings.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Thank you 'MCelliotG' for the info........will play with the receiver later. :-clap
Be safe.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Thanks 'MCelliotG' for the info, will play later with the receiver.
:-clap
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Sorted...........again, thank you.
tompouce
Belgium
My other receiver.. GTMedia Combo can't find it but well Radio Alouette tp ! (11465H 667)
how do you start a scan for this channel from this screen?
You just press OK on the remote. That's how it works on my Dreambox anyway..
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
On receiver:- 'Main Menu/Setup/Reception/Manual Scan' then scroll down to 'Type of scan', change value to read 'User defined transponder' then input/change all the column values to agree with your intended transponder search.......... press 'OK' button to make your search. Good luck. :Y
