RAI DAB+ feed from 5 West
7mdish
Milan, Italy
Could anyone produce a full list of all available DAB+ transponders on all european satellites?
I do not find any information on usual web sites like flysat or lyngsat. Thanks.
https://github.com/piratfm/eti-tools#satellite-dab-feeds
Satfaca
Melmac (46N, 14.5E)
Melmac
The list above has been missing just a few of them:
Satfaca
Melmac (46N, 14.5E)
Melmac
I've already wanted to ask if anyone knows the name of this station...:-ohcrap :)
cirio70
Laminas 180 - Fracarro UX-TW-LTE(PLL) - C Band - TBS6903 - Octagon SF 8008 -Zgemma H92S
Lombardy - Italy
The name of the station is "No Name Radio" (powered by RAI):-doh
Info (in Italian)
Bye,
Satfaca
Melmac (46N, 14.5E)
Melmac
Right, I provided the same page above.:)
jsda30
edision os mio 4k
spain
It is driving me nutts! It seems there are some incompatibilities between DreamBoxEdit & DreamSet.
Whenever I change the atribute from 4097 to 5002 (either manually in the file or by using DreamSet), next time I read settings from the box by DreamBoxEdit all changed channels get deleted/missed. Contrary DreamSet keeps reading as it should. How to solve this?!
View attachment 153549 View attachment 153550
hi.. i have the same problem now with satdream 10 with my octagon sf8008
dabstreamer work but sound are bad...
finally how did you resolved the problem
can you help me? thanks!
Satfaca
Melmac (46N, 14.5E)
Melmac
#138
Satfaca
Melmac (46N, 14.5E)
Melmac
Satfaca
Melmac (46N, 14.5E)
Melmac
11456 H
- MPX RTL2 - pid 521 239.10.1.10 port 7010
11461 H
- M1 - pid 301 239.0.1.11 port 5001
- M2 - pid 301 239.0.1.12 port 5002
- RTL2 MPX - pid 501 239.10.1.10 port 7010
fedi2eti doesn't even list names for MPX :(
Another change here:
- MPX RTL2 - pid 521 239.0.10.52 port 5052
- MPX FUN - pid 531 239.0.10.53 port 5053
I guess still no solution to reproduce these on E2.
Since the last post about 11456 H (#9) only pid 521 was active.
In the meantime, I discovered that there are now four active pid (511,551,541,561).
Even if it is said here that they are not DAB, tests show me that all these pids are sound carriers. Only visually I can see this.
I still don't know with what audio decoding is possible.
cirio70
Lombardy - Italy
as @Adam792 suggested in this post, every PID carries a Radio Station in MPX format.
More info on MPX over IP HERE
Bye,
Satfaca
Melmac (46N, 14.5E)
Melmac
yes,
if i remember correctly you can do it from E2 menu.
Menu -> Setup -> Playback Recording & Timeshift -> ServiceApp
Happy Xmas!
As I already thought this case has been solved once & for all ... I just noticed that some of the DAB+ channels cannot be heard using the exteplayer3, there's simply silence. However, if I put back to the GSTPlayer, the sound can be heard but distorted as mentioned before.
Here are the channels marked with red.
Are there any special settings adjustmens to be made or how to solve this?!
cirio70
Lombardy - Italy
I just checked the EuroDab Mux and i can play all the stations with ExtePlayer.
BTW, here's my settings (OpenAtv 7.3 latest update):
Ciao
Adam792
Cheltenham
All of the highlighted ones use HE-AACv2 (as opposed to the higher bitrate DAB+ ones which use HE-AACv1), so it's likely to be a decoder bug.
Satfaca
Melmac (46N, 14.5E)
Melmac
Ciao
No il Re quadrato, il Re alla terza potenza!
Now it works! I had this setting for AAC SW decoding set to off. :confused
Satfaca
Melmac (46N, 14.5E)
Melmac
Well, these are not "classic" DAB muxes/ensambles but IP streams. I consider them as DAB anyway.
See Polska, Romania, Espana
andimik
120cm with Stab rotor, TBS 5927 and 6903xv1
Southern Austria
No, you should not. Please don't mix them up.
