new Bosnian package in T2MI
semering
DVB-S2 TBS card
Serbia
EnoSat, can u please help me with info.... how to scan it with TBS card and Astra ?
deeptho
Europe
neumoDVB can also view these channels:
The screenshot shows 4 channels from that mux.
falconXXL
0.9W°, 1.8E°,13E°,16E°,19.2E°,23.5E°,28E°,33E°
Austria
There is finally guide for "how to" install and use astra-sm by Enigma 2,5 missing.
All steps should be detail described. For example the command: astra --analyze "t2mi://#t2mi_pid=4095&t2mi_input=http://127.0.0.1:8001/1:0:1:FA1:190:0:14A2CB2:0:0:0:" does not work on my DM920.
i can start, stop and see the status of astra, but i should get posibility to analyze the transponder and save the channels.
Commands witH astra -analyze" aren't working.
-BASH: ASTRA: COMMAND NOT FOUND
THANK YOU
EnoSat
enosat.euweb.cz
Slovakia
according to new Bosnian package in T2MI
the analyze command works for you, but it does not read PID 4095, how did you enter the PID into lamedb?
falconXXL
Austria
I edited lamedb with dreambox control center e2, is any other tool requiered?
i paste the userbouquet and edited bouquets. so i have the chanel in the favoriten but do not work
astra command answered the same (-BASH: ASTRA: COMMAND NOT FOUND)
EnoSat
enosat.euweb.cz
Slovakia
the important thing is how you have the T2MI pid defined in lamedb
p:T2-MI,c:031fff,c:000fff,f:5
or
p:T2-MI,c:031fff,c:150fff,f:5
PS: post 49 is yours? commands work correctly there
semering
DVB-S2 TBS card
Serbia
@EnoSat Can u please tell me what exactly should I do in order to scan those channels with TBS card in linux ( Astra Cesbo software ) ?
EnoSat
enosat.euweb.cz
Slovakia
I don't use Astra CESBO, but only Astra-SM
PS: Cesbo Help Center - i see MIS support but not T2MI support
https://help.cesbo.com/astra/receiving/dvb/t2mi - this hint has been removed
hey guys - this is a self help forum. DONT expect to be given step by step instructons on how to get stuff working. Follow the instructions from start to finish & if you cant get it to work start again & work through it logically.
If you dont have the patience to work through instructions logically then you do without.
Darko Joksimovic
eutelsat
bosnia and herzegovina
Hi guys! i have vu zero 4k is it posible to whact this chanells on my box! i have lock on that freq. and 16db streinght but when i scan nothing just one 11444H SID 0xfa1! my problem is that i don know anything that you write here about it :) THANKS
Admin edit - A/S
Err please read the message above yours
Follow the rules - if you cant figure the instructions out then you dont get to watch those channels.....
Darko Joksimovic
eutelsat
do you know how to make a car? i dont know anything about this! is it sinto help someone if you can?
A/S edit
If you dont know how you do it then you will do without if you cant be bothered to learn.
If you make a direct appeal for someone to help you off the forum again I shall cancel your account. Thats NOT how forums work especially this one where we have an expectation that people will teach themselves how stuff works from a limited amount of help our members will provide. Ive edited the request out of your previous post.
EnoSat
enosat.euweb.cz
Slovakia
VU zero 4K does not support direct T2MI scanning, the best thing to do is to buy a box with T2MI support and you will have no problems.
stephan94
Bavaria
you can modify the PID directly in the receiver with TS satellite editor .
It's quicker than modifying the lamedb with the computer.
This thread has served its pupose - I shall now close it.
