s-band
- Feb 7, 2016
- Essex
3.5k is a highish but reasonable price for that lot. However, I'd check the Satsio firmware in both indoor & outdoor units to make sure it will do what you want or you can upgrade it. There are some limitations and I'm not sure how much support dB can give and at what cost.Can you cover Rx kit needs with the selling of the Tx or is this a venture into the unknown ?
One problem, that's actually reasonably easy to get around, is that the indoor unit defaults to look for S3satcom servers for NORAD data. There's also the risk that when the NORAD ID numbers exceed 99999 it might not work fully. Although from 2020, see the answer here
