Octagon SF8008 OR VU+ Duo 4K SE?
Nalleman
Motala Sweden
Sweden
Here is 11053 H by far the most problematic.
With the SF8008 (not the Supreme version) I can get a couple of hours in the morning and the evening.
Same thing with the VU+ DUO2.
With the VU+ DUO 4K SE I can get it almost 24/7 if the weather isn't to bad.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Simultaneous scan Identical coax and length. Supreme 12129 absent at that moment but higher at another time and fine right now. This is the boxes measuring themselves though, so does it actually mean anything?
Thanks, impressive graphic.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Not got 12129 so far today but now 21.30hrs, finally secured, albeit with a high BER. the older SF8008 4k Twin tuners (Silabs si2166d) locked as attached:- pics '1', '2', '3'.
The latest Octagon SF8008 4k Twin SUPREME (Avalink AVL2X1)..........nothing!! pic '4'.
Not brilliant pic '5' but shows set up:- same dish, same quad LNB, same cable run, same salon/lounge for the two x receivers so can only assume the newer 'SUPREME' is less sensitive tuner wise!
Again, welcome other dual receivers users results.
View attachment 155021View attachment 155022View attachment 155023View attachment 155024View attachment 155025
The acid test is to swop receivers over and check the result is the same.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Done, tonight but also used tuners 'A' and 'B' on both receivers, same coax......again nothing with the 'SUPREME' model!
Side note only:- the GT Combo still sits there as having a very sensitive tuner as attached, irrespective of all its apparent faults.
Octagon SF8008, pics '1/2/3'
Octagon SF8008 SUPREME, pics 'a/b/c/d'
+ GT Combo.
OK, looks conclusive.
The GTMedia Combo sensitivity is a given (though I've found the f-connector on mine has worked loose from the casing and requires soldering).
antrabe
dreambox7080 dm900 viark droi
spain
i have a doubt surely already replied but i cant find it. There is a manual to install a hdd 2.5" SATA 1000GB / 1TB on octagon SF8008;
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Only have this and is for the Octagon SF8008 4K Twin SUPREME :-
  • M.2-SSD_Installation-instructions_Octagon_SF8008-SUPREME.pdf
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
Like many of us here the sensitivity of tuners is vital. Not at home so cannot attach pics but just to say that (only after my tests and opinion) that the tuners in the newer model Octagon SF8008 4k Twin SUPREME (Avalink AVL2X1) are not as sensitive as the older SF8008 4k Twin tuners (Silabs si2166d). Alicante,España, both receivers connected to the same dish (Marrafa 1.8m PF) and LNB (Inverto Quad Flange)....... def fringe here for 28.2*e, 2F U.K. beam tranponder 12129 V 27500...........the 'Supreme' model showed pixellation whilst the older model retained full image.......12129 always a pain in the butt. :lol: Sorry for lack of pics showing dB, image etc. Perhaps others who have both models can share their findings. :Y
Hi
Please contact Octagon Directly about any problems with the SF8008 Supreme. They have known for months about problems such as the Supreme not being able to receive the advertised low symbol rate transponders and have done Nothing about it. They need to know you are Not Happy with their product and Why. Maybe they will try to fix it if enough people complain.
Email:
Kücükogul Necati
info@octagon-germany.de
Thanks.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Hi
Email:
Kücükogul Necati
Thanks.
Agreed, not much time at the mo but emailed this as a start.........hope is ok!
Best wishes. :Y
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Superb, already had a response (as attached)......looking into low SR issue and asking for more info so I will advise.
A good result for us will also mean a good result for Octagon.......sure they know we ain't purely tv watchers.:-lol
Anyway, pleased to see a reply and big thumbs up and thanks to them. :-applause
Is there a specification on the box confirming the supreme tuner sensitivity ?
Does 'Supreme' actually mean better ?
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Hola 'CH'..........not seen an actual Octagon official tuner sensitivity spec but below is part of the spec translation from Spanish relating to the 'SUPREME'.........sensitivity not detailed as you can see but merely stating 'set new standards with an advanced tuner and demodulator for optimized reception' :oops: this was part of the full receiver build indicated on the site I bought the SF8008 from (dealt with them for many many years);-
Octagon SF8008 Supreme 4K UHD Twin S2x Receiver
Octagon SF8008 Supreme Twin incorporates a world first: the M.2 interface for the internal integration of M.2 hard drives.
The receiver with Dual OS meets all the requirements of a multimedia device and now opens up even more possibilities.
By using a new tuner and demodulator, the already high quality was further improved. Supreme models set new standards with an advanced tuner and demodulator for optimized reception, the integration of an M.2 interface for internal hard drives, permanently installed dual-band WiFi (2.4/5 GHz) with up to 1200 Mbps and Bluetooth 5.1. an innovative combination of performance and connectivity.
Then it does look as though the design parameters for the replacement are wrong.
There is a possibility the revised front end has reduced the chance of oversaturation or is better compatible with a larger range of outdoor devices, but they have missed a trick with low signal reception being worse than the predecessor(s)
Has anyone tried terrestrial performance of the Supreme against the first generation ?
The "Supreme" receiver option to use an M.2 drive is not a great advance in my personal opinion.
Although an M.2 drive can be faster than an SSD, in terms of actual use within the receiver for recording and playback I dont see any real advantage of M2 over SSD.
antrabe
spain
So in conclusion is not worthy to upgrade our old sf8008 to supreme.
about the hdd i found how to install i have some pictures but its risky to weld he wires over some componenets.
Mickha
North West
You usually have plugin connectors, to attach an internal hard drive.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Emailed them this morning...
Hi and a very good morning to you,
I own a Octagon SF8008 Supreme (bought just recently) beside also owning
an Octagon SF8008 4K.
What I find disappointing in the new Model (Supreme) is that the Tuner
is not as sensitive as the older
Model, especially in Low Symbol rates. I would like very much to see
some sort of updates from your side
so as to make this new Model Supreme in par with older Model as regards
Tuner sensitivity.
I know I can rely on you because you always come up with first Class
Receivers.
Thank you in advance.
Best regards to all........
And Alleluia!
for tuner, blindscan and low sybol rate issue we will realese soon new driver
br octagon
Thats word for word from them.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Tuner sensitivity.
Receivers.
And Alleluia!
br octagon
Well written and nice to see response, thanks. :Y Let us hope Octagon come good with this.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
