New DAB mux @ 9 East
Satfaca
Melmac (46N, 14.5E)
Melmac
Everything back to normal at the moment.
andimik
120cm with Stab rotor, TBS 5927 and 6903xv1
Southern Austria
On 101 and 102 there is the Mux "RADIODIG UMBRIA" (0x5016)
So it has nothing to do with Tuscany
cirio70
Laminas 180 - Fracarro UX-TW-LTE(PLL) - C Band - TBS6903 - Octagon SF 8008 -Zgemma H92S
Lombardy - Italy
Finally i found the time to check on the new mux :
root@sf8008:~# wget 127.0.0.1:8001/1:0:1:1:1:2:5A0000:0:0:0 -q -O- | tsniv2ni 7030 | ni2out --list
Ensemble: RADIODIG UMBRIA  (0x5016)
 #  Programme Label   Serv.Id.  P/S SubCh Capac.Units   Prot.   Bitrate Mode
 1: MaxRadio Classic  (0x53ac)  Prm   1   72 (  0- 71)  eep-3a  96 Kb/s DAB+
 2: Radio Blu         (0x531b)  Prm   2   72 ( 72-143)  eep-3a  96 Kb/s DAB+
 3: Radio Galileo     (0x5496)  Prm   3   72 (144-215)  eep-3a  96 Kb/s DAB+
 4: 'R. Studio Delta  (0x53fb)  Prm   4   72 (216-287)  eep-3a  96 Kb/s DAB+
 5: *SIMPLY*          (0x6158)  Prm   5   72 (288-359)  eep-3a  96 Kb/s DAB+
 6: DOT Radio         (0x5583)  Prm   6   72 (360-431)  eep-3a  96 Kb/s DAB+
 7: 'RADIO BRUNO DAB  (0x534d)  Prm   7   64 (432-495)  eep-2a  64 Kb/s DAB+
 8: RADIO K55         (0x5ccd)  Prm   8   48 (496-543)  eep-3a  64 Kb/s DAB+
 9: BIRIKINA DAB      (0x536e)  Prm   9   48 (544-591)  eep-3a  64 Kb/s DAB+
10: Bellla&Monella    (0x5370)  Prm  10   48 (592-639)  eep-3a  64 Kb/s DAB+
11: PITERPAN DAB      (0x5373)  Prm  11   48 (640-687)  eep-3a  64 Kb/s DAB+
12: #TST              (0x0d)  Prm  12   32 (688-719)  eep-4a  64 Kb/s DAB+
13: #TST2             (0x0e)  Prm  13   36 (720-755)  eep-3a  48 Kb/s DAB+
Free CUs on this multiplex = 108
Stations 12 and 13 are muted.
Fun Fact: many of these stations broadcast the "Dinamic Label+" which is a novelty for Italian DAB stations over satellite
andimik
Southern Austria
Semms the tests are over. There are only two MIS instead of four on that frequency.
Satfaca
Melmac (46N, 14.5E)
Melmac
Has this DAB mux reapeared somewhere, anyone spotted it maybe?
Attempting to listen again to DAB+ Italian at 9.0E on 11727 V, 30000, 3/4,8PSK was unsuccessful on both Linux and Windows, as I discovered that pid DAB 7031 and 7131 have no active stream.
TSReader indicates the presence of these DAB pids, but that's all.
Perhaps they have been moved to one of the Italian muxes on the Italy spot(?!), which I don't have access to with the antenna in my area.
I would like to know if anyone can try to determine whether these DAB streams exist.
Adam792
Cheltenham
They're both still on there -
tune-s2 11727 V 30000 -system DVB-S2 -lnb UNIVERSAL
status Locked | signal -31.6 dBm | snr 11.9 dB | ber 0 | FE_HAS_LOCK
Closing frontend ...
dvbstream -o 7031 | tsniv2ni 7031 | ni2out --list
dvbstream v0.7.01 - (C) Dave Chapman 2001-2004
Released under the GPL.
Latest version available from http://dvbtools.sourceforge.net/
dvbstream will stop after -1 seconds (71582788 minutes)
Output to stdout
Streaming 2 streams
DAB Italia       (0x5009)
 0 : RR News          (0x5284) Pri subch=21 start=540 CUs= 36 PL=eep-3a bitrate=48 DAB+
 1 : M DUE O DANCE    (0x5287) Pri subch=18 start=456 CUs= 24 PL=eep-3a bitrate=32 DAB+
 2 : * RDS *          (0x5264) Pri subch= 8 start=288 CUs= 48 PL=eep-3a bitrate=64 DAB+
 3 : RMALB.IA         (0x52cc) Pri subch=15 start=372 CUs= 36 PL=eep-3a bitrate=48 DAB+
 4 : Radio Radicale   (0x5210) Pri subch= 2 start= 36 CUs= 36 PL=eep-3a bitrate=48 DAB+
 5 : Deejay           (0x5214) Pri subch= 3 start= 72 CUs= 48 PL=eep-3a bitrate=64 DAB+
 6 : SERIE A con RDS  (0x5228) Pri subch=14 start=612 CUs= 36 PL=eep-3a bitrate=48 DAB+
 7 : Radio 24         (0x5245) Pri subch= 7 start=252 CUs= 36 PL=eep-3a bitrate=48 DAB+
 8 : 105 DAB          (0x5286) Pri subch=11 start=336 CUs= 36 PL=eep-3a bitrate=48 DAB+
 9 : Radio 24 +1      (0x5282) Pri subch=19 start=480 CUs= 36 PL=eep-3a bitrate=48 DAB+
10 : Capital          (0x5219) Pri subch= 5 start=156 CUs= 48 PL=eep-3a bitrate=64 DAB+
11 : Deejay 30 Songs  (0x5283) Pri subch=20 start=516 CUs= 24 PL=eep-3a bitrate=32 DAB+
12 : * RDS * Relax    (0x5281) Pri subch=16 start=408 CUs= 24 PL=eep-3a bitrate=32 DAB+
13 : Capital Funky    (0x5285) Pri subch=17 start=432 CUs= 24 PL=eep-3a bitrate=32 DAB+
14 : M DUE O          (0x5233) Pri subch= 6 start=204 CUs= 48 PL=eep-3a bitrate=64 DAB+
15 : R101             (0x5215) Pri subch= 4 start=120 CUs= 36 PL=eep-3a bitrate=48 DAB+
16 : ACI Radio        (0x5227) Pri subch=10 start=576 CUs= 36 PL=eep-3a bitrate=48 DAB+
17 : Radio Maria      (0x51cc) Pri subch= 1 start=  0 CUs= 36 PL=eep-3a bitrate=48 DAB+
dvbstream -o 7131 | tsniv2ni 7131 | ni2out --list
Output to stdout
Streaming 2 streams
#EuroDab Italia  (0x5003)
 0 : #RTL102.5 napul� (0x529f) Pri subch= 8 start=588 CUs= 48 PL=eep-3a bitrate=64 DAB+
 1 : RadioItaliaTrend (0x5221) Pri subch=11 start= 48 CUs= 36 PL=eep-3a bitrate=48 DAB+
 2 : Radio Libert�    (0x5276) Pri subch=17 start= 84 CUs= 24 PL=eep-3a bitrate=32 DAB+
 3 : #RadioFreccia    (0x5293) Pri subch= 1 start=240 CUs= 72 PL=eep-3a bitrate=96 DAB+
 4 : SUBASIO XL       (0x5fee) Pri subch=20 start=744 CUs= 36 PL=eep-3a bitrate=48 DAB+
 5 : KISSKISS         (0x5225) Pri subch=12 start=108 CUs= 36 PL=eep-3a bitrate=48 DAB+
 6 : #RTL 102.5 b&s   (0x5296) Pri subch= 4 start=432 CUs= 36 PL=eep-3a bitrate=48 DAB+
 7 : #RTL 102.5       (0x5218) Pri subch= 0 start=168 CUs= 72 PL=eep-3a bitrate=96 DAB+
 8 : 105              (0x5211) Pri subch=23 start=780 CUs= 48 PL=eep-3a bitrate=64 DAB+
 9 : RMC              (0x5213) Pri subch=18 start=672 CUs= 36 PL=eep-3a bitrate=48 DAB+
10 : #RTL 102.5 news  (0x5294) Pri subch= 6 start=504 CUs= 42 PL=eep-3a bitrate=56 DAB+
11 : #RTL1025caliente (0x5297) Pri subch= 5 start=468 CUs= 36 PL=eep-3a bitrate=48 DAB+
12 : inBlu 2000       (0x5126) Pri subch=21 start=828 CUs= 24 PL=eep-3a bitrate=32 DAB+
13 : RVaticana Ita +  (0x510e) Pri subch=15 start=144 CUs= 24 PL=eep-3a bitrate=32 DAB+
14 : BBC WorldService (0xc238) Pri subch= 7 start=546 CUs= 42 PL=eep-3a bitrate=56 DAB+
15 : #RTL 102.5 doc   (0x52ef) Pri subch= 9 start=636 CUs= 36 PL=eep-3a bitrate=48 DAB+
16 : #RadioZeta       (0x5299) Pri subch= 2 start=312 CUs= 72 PL=eep-3a bitrate=96 DAB+
17 : Radio Italia SMI (0x5220) Pri subch=10 start=  0 CUs= 48 PL=eep-3a bitrate=64 DAB+
18 : #RTL 102.5 best  (0x5298) Pri subch= 3 start=384 CUs= 48 PL=eep-3a bitrate=64 DAB+
19 : Virgin Radio     (0x5241) Pri subch=19 start=708 CUs= 36 PL=eep-3a bitrate=48 DAB+
Satfaca
Melmac (46N, 14.5E)
Melmac
Running here as before as well.
You were right, @Adam. The Italian DAB streams are working.
I haven't installed the tsniv2ni app on Ubuntu with the new kernel.
Many thanks :)
