RAI DAB+ feed from 5 West
jsda30
edision os mio 4k
spain
hi everybody!
someone have the services id for the mux dab radios obervayern south (7a) at 7e?
i have the fak channel and now im creating the userbouquet but i dont have the service id...
because always error whe i used telnet for get the service id channel radio like other mux of bavarian radios...
Satfaca
Melmac (46N, 14.5E)
Melmac
Do you mean this?
I tried the DAB WDR stream under Windows. I could view it with PotPlayer and play it at 19.2E(11603 V) and 23.5E(12644 V,2200).
Unfortunately, no matter how many players I tried, I couldn't listen to it.
And with the Ayecka device, the same thing happens.
That's why I provide the recorded TS files for those who know how to decode these streams; you might say they are "protected" for the uninitiated.
You can download them here.
Satfaca
Melmac (46N, 14.5E)
Melmac
Same here, must be some fault in the stream.
Adam792
Cheltenham
The 9A mux on 19.2°E 11604V /23.5°E 12645V is now carrying actual programmes again -
WDR Ruhrgebiet is just a tone but the other services are carrying WDR2 and WDR4 programming as signalled.
Thanks, @Adam792, Indeed, WDR 2 works on 11604 V; only Ruhrgebiet has test sound.
I hope this is not a false alarm, but the RAI MIS(including RAI Mux DAB+) on 11013 V,35300,2/3,8PSK has left Eutelsat 5West(?). There is no signal trace on this frequency,
What do you find in your area?
Here is what transponders are active at 5.0W in my area atm.
cirio70
Laminas 180 - Fracarro UX-TW-LTE(PLL) - C Band - TBS6903 - Octagon SF 8008 -Zgemma H92S
Lombardy - Italy
No, you're right. 11013 V was turned off last week.
All the streams are now on 12563 V same parameters.
Here they are:12564 V,35300,2/3,8PSK,PLS-Root 16416-Mis 1,3,5,11
5.0W_12564 V,35300,2/3,8PSK, Root 16416-Stream 11 - RAI Mux DAB+
DAB+ RAI (0x5001)
0 : Rai Radio1 (0x5201) Pri subch= 1 start= 0 CUs= 84 PL=eep-3a bitrate=112 DAB+
1 : Rai Radio2 (0x5202) Pri subch= 2 start= 84 CUs= 84 PL=eep-3a bitrate=112 DAB+
2 : Rai Radio3 (0x5203) Pri subch= 3 start=168 CUs= 84 PL=eep-3a bitrate=112 DAB+
3 : Rai GrParlamento (0x5206) Pri subch= 4 start=252 CUs= 42 PL=eep-3a bitrate=56 DAB+
4 : Rai Isoradio (0x5209) Pri subch= 5 start=294 CUs= 78 PL=eep-3a bitrate=104 DAB+
5 : RaiTuttaItaliana (0x5207) Pri subch= 6 start=372 CUs= 78 PL=eep-3a bitrate=104 DAB+
6 : Rai R Classica (0x5205) Pri subch= 7 start=450 CUs= 78 PL=eep-3a bitrate=104 DAB+
7 : Rai Radio1 Sport (0x520f) Pri subch= 8 start=528 CUs= 48 PL=eep-3a bitrate=64 DAB+
8 : Rai R Techete' (0x52f1) Pri subch=10 start=576 CUs= 66 PL=eep-3a bitrate=88 DAB+
9 : RaiR Live Napoli (0x52f2) Pri subch=11 start=642 CUs= 78 PL=eep-3a bitrate=104 DAB+
10 : Rai Radio Kids (0x52f3) Pri subch=12 start=720 CUs= 66 PL=eep-3a bitrate=88 DAB+
11 : No Name Radio (0x520a) Pri subch=13 start=786 CUs= 78 PL=eep-3a bitrate=104 DAB+
5.0W_12564 V,35300,2/3,8PSK,Mis 11_RAI Mux DAB+ stream with neumoDVB
cirio70
Lombardy - Italy
RAI DAB+ 5W Is it not in this "Cusano Italy" radio?
Radio Cusano Campus is no longer transmitted on RAI mux.
You can find it on HotBird 13E 11179H 27500 2/3
