OCTAGON SF8008 E2 4K UHD
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
The SF8008 Supreme looks like it has a great blindscan until it is closely examined. The SF8008 Supreme is logging transponders in a blindscsan that it cannot solve.
61 West-Cband is a good example.
                         Scan Report
< File created on Sunday, March 03, 2024 at 15:57:38 >
< Satellite =  61.0W C-band Amazonas 2/3/5 61.1 W >
< Receiver =  SF8008-Supreme >
< Enigma2 Image = Tnap 5.1 >
< Kernel Version = 4.4.35 >
< DVB Driver Date = 2024-01-04 >
< Blindscan Frequency Range = 3625 to 4800 MHz >
< Blindscan Symbol Rate Range = 1 to 60 Msps >
< Blindscan Only Free Channels or Services? = False  >
< Tuner = Tuner A: AVL62X1 (DVB-S2) >
< 'DVB-S2 QPSK 3730V / 2435 / AUTO' > Tp# 1
< Transponder SNR =['652.35db'-UnLocked], LNB Power = 78.90 >
< 'DVB-S2 QPSK 3738H / 2885 / AUTO' > Tp# 2
< Transponder SNR =['652.35db'-UnLocked], LNB Power = 75.23 >
< 'DVB-S2 QPSK 3782H / 2434 / AUTO' > Tp# 3
< Transponder SNR =['652.35db'-UnLocked], LNB Power = 72.48 >
< 'DVB-S2 QPSK 3835V / 2527 / AUTO' > Tp# 4
< Transponder SNR =['652.35db'-UnLocked], LNB Power = 81.66 >
< 'DVB-S2 8PSK 3889H / 7500 / 3/4' > Tp# 5
< [1] C CARIOCA  1:0:19:1:0:1:BAD0F31:0:0:0: SNR = 9.32  />
< [2] 3889H SID 0x01  1:0:1:1:0:1:BAD0F31:0:0:0: SNR = 9.32  />
< Transponder SNR =['9.32db'-Locked], LNB Power = 85.33 >
< 'DVB-S2 8PSK 3898H / 7501 / 3/4' > Tp# 6
< [3] SERVICE 03_03_24   (Radio #1)  1:0:2:2:0:0:BAD0F3A:0:0:0: SNR = 9.29  />
< Transponder SNR =['9.29db'-Locked], LNB Power = 87.16 >
< 'DVB-S2 8PSK 3907H / 7500 / 2/3' > Tp# 7
< [4] BOA x BAN  1:0:19:1:0:0:BAD0F43:0:0:0: SNR = 7.62  />
< Transponder SNR =['7.62db'-Locked], LNB Power = 87.16 >
< 'DVB-S2 8PSK 3941V / 5000 / 3/4' > Tp# 8
< [5] SBTRS_HD  1:0:1:CA40:652:652:BAD8F65:0:0:0: SNR = 12.04  />
< [6] SBTRS_1SEG  1:0:C0:CA58:652:652:BAD8F65:0:0:0: SNR = 12.04  />
< Transponder SNR =['12.04db'-Locked], LNB Power = 84.41 >
< 'DVB-S2 16APSK 3946H / 7500 / 2/3' > Tp# 9
< [7] 3946H SID 0x01  1:0:1:1:A0:0:BAD0F6A:0:0:0: SNR = 9.97  />
< Transponder SNR =['9.97db'-Locked], LNB Power = 89.00 >
< 'DVB-S2 8PSK 3959H / 3750 / 2/3' > Tp# 10
< [8] ALTV  1:0:0:1:0:0:BAD0F77:0:0:0: SNR = 8.73  />
< Transponder SNR =['8.73db'-Locked], LNB Power = 86.24 >
< 'DVB-S2 8PSK 3968H / 9875 / 2/3' > Tp# 11
< [9] TELEFUTURO HD  1:0:1:1:1:2AF:BAD0F80:0:0:0: SNR = 8.17  />
< [10] LA TELE HD  1:0:1:2:1:2AF:BAD0F80:0:0:0: SNR = 8.17  />
< [11] NOTICIAS PARAGUAY  1:0:1:3:1:2AF:BAD0F80:0:0:0: SNR = 8.17  />
< [12] MONUMENTAL TV  1:0:1:4:1:2AF:BAD0F80:0:0:0: SNR = 8.17  />
< [13] PRO TV  1:0:1:5:1:2AF:BAD0F80:0:0:0: SNR = 8.17  />
< [14] E40 TV SD  1:0:1:6:1:2AF:BAD0F80:0:0:0: SNR = 8.17  />
< Transponder SNR =['8.17db'-Locked], LNB Power = 89.91 >
< 'DVB-S2 16APSK 3971V / 6741 / 3/4' > Tp# 12
< Transponder SNR =['9.29db'-UnLocked], LNB Power = 85.33 >
< 'DVB-S2 8PSK 3975H / 2500 / 2/3' > Tp# 13
< [15] ALESP MPEG2  1:0:1:1:1:1:BAD0F87:0:0:0: SNR = 7.6  />
< Transponder SNR =['7.6db'-Locked], LNB Power = 82.57 >
< 'DVB-S2 8PSK 3983H / 7501 / 2/3' > Tp# 14
< [16] 3983H SID 0x01  1:0:1:1:2:0:BAD0F8F:0:0:0: SNR = 8.0  />
< Transponder SNR =['8.0db'-Locked], LNB Power = 88.08 >
< 'DVB-S2 8PSK 3990V / 5000 / 3/4' > Tp# 15
< [17] TBC  1:0:1:1:1:1:BAD8F96:0:0:0: SNR = 10.23  />
< [18] VIVAX  1:0:1:2:1:1:BAD8F96:0:0:0: SNR = 10.23  />
< Transponder SNR =['10.23db'-Locked], LNB Power = 79.82 >
< 'DVB-S2 QPSK 3991H / 1667 / 4/5' > Tp# 16
< [19] Telerama_Ecuador  1:0:1:1:1:1:BAD0F97:0:0:0: SNR = 7.6  />
< Transponder SNR =['7.6db'-Locked], LNB Power = 79.82 >
< 'DVB-S2 QPSK 4018H / 27538 / 3/4' > Tp# 17
< Transponder SNR =['8.89db'-Locked], LNB Power = 88.08 >
< 'DVB-S2 8PSK 4022V / 5000 / 3/4' > Tp# 18
< [20] TV Pajucara Movel  1:0:C0:1BD8:DE:DE:BAD8FB6:0:0:0: SNR = 10.21  />
< [21] TV Pajucara HD  1:0:1:1BC0:DE:DE:BAD8FB6:0:0:0: SNR = 10.21  />
< Transponder SNR =['10.21db'-Locked], LNB Power = 87.16 >
< 'DVB-S2 QPSK 4040V / 23333 / 4/5' > Tp# 19
< [22] TCM HD  1:0:1:A:1:1:BAD8FC8:0:0:0: SNR = 10.24  />
< [23] TOON E HD  1:0:1:B:1:1:BAD8FC8:0:0:0: SNR = 10.24  />
< [24] CBS  1:0:1:C:1:1:BAD8FC8:0:0:0: SNR = 10.24  />
< [25] HGTV  1:0:1:D:1:1:BAD8FC8:0:0:0: SNR = 10.24  />
< [26] Food  1:0:1:E:1:1:BAD8FC8:0:0:0: SNR = 10.24  />
< [27] Travel  1:0:1:F:1:1:BAD8FC8:0:0:0: SNR = 10.24  />
< [28] Discovery  1:0:1:10:1:1:BAD8FC8:0:0:0: SNR = 10.24  />
< [29] Nick  1:0:1:11:1:1:BAD8FC8:0:0:0: SNR = 10.24  />
< [30] ESPN U HD  1:0:1:15:1:1:BAD8FC8:0:0:0: SNR = 10.24  />
< [31] ESPN HD  1:0:1:16:1:1:BAD8FC8:0:0:0: SNR = 10.24  />
< [32] ESPN 2 HD  1:0:1:17:1:1:BAD8FC8:0:0:0: SNR = 10.24  />
< [33] ESPN SEC HD  1:0:1C:18:1:1:BAD8FC8:0:0:0: SNR = 10.24  />
< [34] CNN HD  1:0:1:19:1:1:BAD8FC8:0:0:0: SNR = 10.24  />
< [35] CruiseSat Live  1:0:1:1B:1:1:BAD8FC8:0:0:0: SNR = 10.24  />
< [36] ESPN SYN 780  1:0:1:C8:1:1:BAD8FC8:0:0:0: SNR = 10.24  />
< [37] Rai Italia 1 HD (NTSC)  1:0:1:12C:1:1:BAD8FC8:0:0:0: SNR = 10.24  />
< [38] CE_RTL  1:0:1:12D:1:1:BAD8FC8:0:0:0: SNR = 10.24  />
< [39] TVEA HD  1:0:1:15E:1:1:BAD8FC8:0:0:0: SNR = 10.24  />
< Transponder SNR =['10.24db'-Locked], LNB Power = 89.00 >
< 'DVB-S2 16APSK 4092H / 11441 / 5/6' > Tp# 20
< Transponder SNR =['1.94db'-UnLocked], LNB Power = 88.08 >
< 'DVB-S2 QPSK 4139H / 4543 / 3/4' > Tp# 21
< [40] 4139H SID 0x01  1:0:1:1:1:0:BAD102B:0:0:0: SNR = 8.9  />
< Transponder SNR =['8.9db'-Locked], LNB Power = 85.33 >
< 'DVB-S2 32APSK 4169V / 3409 / 3/4' > Tp# 22
< Transponder SNR =['555.36db'-UnLocked], LNB Power = 85.33 >
< 'DVB-S2 QPSK 4172V / 1667 / 5/6' > Tp# 23
< [41] ABC TV PY BK  1:0:19:2:1:1:BAD904C:0:0:0: SNR = 13.22  />
< Transponder SNR =['13.22db'-Locked], LNB Power = 85.33 >
< 'DVB-S2 8PSK 4177H / 3750 / 3/4' > Tp# 24
< [42] TV CAPIXABA 1SEG  1:0:C0:42F8:217:217:BAD1051:0:0:0: SNR = 10.43  />
< [43] TV CAPIXABA HD  1:0:1:42E0:217:217:BAD1051:0:0:0: SNR = 10.43  />
< Transponder SNR =['10.43db'-Locked], LNB Power = 76.15 >
< 'DVB-S2 QPSK 4182V / 3900 / 4/5' > Tp# 25
< 'DVB-S2 16APSK 4509V / 6460 / AUTO' > Tp# 26
< Transponder SNR =['10.83db'-Locked], LNB Power = 89.00 >
< 'DVB-S2 QPSK 4591V / 5076 / AUTO' > Tp# 27
< Transponder SNR =['652.35db'-UnLocked], LNB Power = 91.75 >
< 'DVB-S2 16APSK 4607V / 2667 / 4/5' > Tp# 28
< Transponder SNR =['9.03db'-UnLocked], LNB Power = 89.00 >
< 'DVB-S2 QPSK 4611V / 2667 / AUTO' > Tp# 29
< Transponder SNR =['8.75db'-UnLocked], LNB Power = 87.16 >
< 'DVB-S2 QPSK 4664V / 1310 / AUTO' > Tp# 30
< 'DVB-S2 QPSK 4673V / 2455 / AUTO' > Tp# 31
< Transponder SNR =['652.35db'-UnLocked], LNB Power = 88.08 >
< 'DVB-S2 QPSK 4676V / 2762 / AUTO' > Tp# 32
< 'DVB-S2 16APSK 4700V / 2969 / AUTO' > Tp# 33
< Transponder SNR =['8.89db'-UnLocked], LNB Power = 91.75 >
< 'DVB-S2 16APSK 4718V / 4166 / AUTO' > Tp# 34
< Transponder SNR =['9.71db'-Locked], LNB Power = 91.75 >
< 'DVB-S2 16APSK 4736V / 4319 / AUTO' > Tp# 35
< Transponder SNR =['6.99db'-UnLocked], LNB Power = 89.00
Blind Scan Time = 13 Min. 13 Sec.
43 Channels ( TV = 42  Radio = 1)  35 of 35 Transponders Scanned.
suedschwede
2.7m Laminas+Polarmount+JPC-Posi+SF8008
DE
New Driver for Test, SF8008 Supreme only!!!
SF8008-SUPREME_LOW-SR_test_220424 Driver - Treiber:
[sf8008 Supreme] update drivers
- Test für Niedrige Symbolraten.
- Try fix. for Low Symbol Rate.
- Düsük (alcak) Sembol hizi icin.
Datei hi-dvb.ko per ftp nach /lib/modules/4.4.xx/extra kopieren und box neustarten.
copy via ftp files hi-dvb.ko to /lib/modules/4.4.xx/extra and reboot box.
hi-dvb.ko dosyayi ftp ile /lib/modules/4.4.xx/extra ya kopyalayin ve cihazinizi yeniden baslatin.
Info: 2 Treiber files zum testen. 2 Driver files for testing. 2 ayri test sürümü. (hi-dvb.ko)
OCTAGON GERMANY Support
  • SF8008-SUPREME_LOW-SR_test_220424.zip
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Good afternoon 'suedschwede' and thanks for the post and upload.
Myself, have seen no improvement using the 'New Driver for Test' x 2 files for the Octagon SUPREME model.
12620 V 890 managed a strong lock at 8.0ºw on the 'SUPREME', sadly the other two low SR's failed to secure........whilst the same three were locked on the earlier model with the Silabs Si2166D tuners.
At the mo not able to test the 'SUPREME' with software using a below lock .dB reading, may show something!........perhaps when time allows you can show what yourself and others are finding using the 'Test' files.
Again, your interest is appreciated. :Y
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
suedschwede
DE
I don't have any Supreme here, I just got the drivers from esmos (Octagon Germany) and posted them here in the forum :)
suedschwede
DE
Test_3 Test Driver - Treiber:
- Blindsuche fix.
- Test für Niedrige Symbolraten Lock fix.
- Blinscan fix.
- Try fix. for Low Symbol Rate Lock fix.
- Kör arama fix.
- Düsük (alcak) Sembol hizi Lock icin fix.
  • Test_3.zip
antrabe
dreambox7080 dm900 viark droi
spain
Here with the old SF8008 before supreme not issue to lock this TP
I noticed on Monday when swopping receivers over that Openeight firmware (6.8) has not been updated for a couple of weeks.
There is a separate section for the 8008M, which I assume is for the mini.
So, since the 8008 Supreme version has a different front end, do either of the OpenEight versions work on the new box ?
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
Openeight is supposed to be based on OpenPLi, and is part of OE Alliance. Openeight supplies their own enigma2 part of the image, and OE Alliance supplies almost everything else. What is needed to run a particular brand of receiver is in OE Alliance, and not in OpenEight.
The driver files for the SF8008 Supreme and the SF8008 are lumped into one package. Most likely this was done as convenience, but it seems to work well. Everything needed to run the SF8008 Supreme was added to OE Alliance and OpenPLi months ago. So any enigma2 SF8008 image made by Openeight within the last three months should also work on the Supreme.
OK, but what about the recent lack of updates ?
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
Updates are the responsibility of the image group. There are OE Alliance updates and there are individual image group updates. Whoever makes the Openeight image is responsible for updating it. The Openeight image group may feel no updates are needed right now, or they may simply not have anything to add at the moment.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
'CH'.........'OpenEight 6.8' working 100% on the 'SUPREME'..............but very old Python version......no online updates available as yet! :(
View attachment 155531View attachment 155532View attachment 155533View attachment 155534
Thank you for clarifying.
I wasn't faulting the firmware as it stands but if OpenEight is being promoted as official partner for the latest 8008 receiver then the update delay may possibly be down to refining the later front end without losing integrity of the older version(s).
What tuner/demod is within the 8008 mini?
frankviana
Satellites/tv
Brazil
Hello for all...
Since 2021 we Brazilians need a way to fix nim_sockets for sf8008 and only OpenSpa show the correct options...
For fix this need major changes?
Thx.
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
Hello for all...
Thx.
There was a thread about this a year or two ago on OpenPli. I had a similar issue with the ATSC usb tuner being recognized as DVB-C. This problem has existed in various forms since Octagon released the SF8008, and this is why I say Octagon does not have "In House" engineers.
You were given a set of drivers to test but you never bothered to reply back or even comment whether they worked. That was the best time to get your problem fixed because someone that knew how could fix it. You missed a good opportunity!
You could try getting the drivers from the OpenSpa image and installing them in the image of your choice. That option will probably work if the problem is indeed fixed in OpenSpa. OpenSpa is closed source, but they can't really hide the drivers.
frankviana
Satellites/tv
Brazil
Drivers or comments on how to solve the problem have never been available (including for tests).
Yes, OpenSPA works very well as DVB-T (ISDB-T), except crash when changing tuner ... but this can be fixed. The interesting thing is that we have lock and video/sound.
Where do I find these drivers at OpenSPA to replace and test on OpenATV and OpenPli?
/modules/extra?
Thanks.
frankviana
Satellites/tv
Brazil
/modules/extra?
Thanks.
After replace some media drivers don't recognize anymore my dvb usb (/media/usb/siano/smsusb.ko, media/common/siano/*. I need reinstall siano.
I found this folder dvbcore/spa-dvb-core.ko, mabye missing this driver to work on OpenAtv and OpenPli.
No problem.
el bandido
1.2 meter KU band
3.6 meter C band
Enigma2 Receivers
Atlanta, Ga. USA
/modules/extra?
Thanks.
You were sent two drivers to test and never responded.
That was the best time to get your problem fixed!
The correct path is: /lib/modules/4.4.35/extra
Try copying the entire extra folder from OpenSpa image to the image of your choice. Reboot.
frankviana
Satellites/tv
Brazil
I tried, but OpenPli always show gray channels (all my boxes) and now, OpenPli 9.0, show as S2x too. I think your drivers work only for ATSC. See:
Thx
