viasat card on azbox
jozeff
Azbox Premium HD, Technomate 1500CI, Viasat 7700, Windows 7
London UK
Hi all!
I am trying to pair my official Viasat Ukraine card. the box recognises the card as Nds but I cannot figure out my box key the box number is only 16 digits instead or 11 digits or 17 hex. What should I do? Any help is much appreciated . I have Azbox Premium and run the latest firmware 4890 and latest multicas b7
john_graydon
Dublin....Ireland
Is it an n*s 2 or new 3 card. I know they are a bitch to set up.
Edit.....Just found out that your card is the new n*s 3 one.
To get boxkey remove 1st and last numbers, you will be left with 9 numbers.
You need to convert to Hex in windows calculator in advance mode. When you convert to hex you will have 7 digits. Put an 0 in front of these numbers and you have your boxkey. Insert this in the newcs.xml file. It will work now.
jozeff
London UK
Thanks John, but the problem is I have a 16 digit box number and if you take the first and the last digit off you and conver to hex you get 12 digits instead of 7. I am really stuck with this box... Any other ideas how to get that box key?
John is no longer a regular contributor to the forum and only visits occasionally - he hasnt been on since August.
jozeff
London UK
Thanks, Analoguesat! Is it possible to get in touch with him somehow. He seems to be knowledgeable in my case.
Not unless he sees this thread on his next visit. Under UK data protection laws we cannot give out contact details for any members or staff.
jozeff
London UK
Fair enough. Can you contact him on my behalf and ask for his permission to contact him. I would really appreciate if you could. I am stuck with this stupid Viasat Strong 7700 box and cannot figure out how to get the box key right.
cyberdek
I had a Viasat Ukraina card 1yr ago too. I have a Dreambox 7000 (and now yet one 8000HD).
I couldn't get the card working either, so shipped back Strong7700 with card to my inlaws.
End of this week (6-8 Jan 2011) I will again receive this Viasat Ukraine card for testing in my new DB8000.
Any news about this box key problem? I had the same problem on my first try.
cyberdek
Yesterday again put Viasat card in Dreambox 7000.
And it worked. Cccam gives all info about the card (NDS), and my local share tot my second receiver (DB8000) works too!
Boxkey should be made like this:
- on sticker on Strong (or in setup screen of SRT7700) is serial type "12345 1234567890 1"
- remove first 5 digits and last 1 digit (thus results in "1234567890")
- HEX this 10-digit number
- should result in 8-digit hex boxkey (if only 7, add "0" as first digit)
Good luck!
cyberdek
forget this story. card only recognised like nds, but no ecms nor emms
only this:
card reader /dev/sci0
handled 0(0) ecms and 0(0) emms
Nds card 4d70
Entitlement info
0064 02-03-2004
0096 02-03-2004
0ff3 06-03-2004
bad news..
igor19
13E 5E 4W 7W 75E 53E 46E 53E 60E
israel
only this:
Nds card 4d70
Entitlement info
0064 02-03-2004
0096 02-03-2004
0ff3 06-03-2004
bad news..
Hello,
Is any news about viasat ukraine 0931 card?
I khow it works in some servers, i watched it on my tv.
ABARKIE
Vu Duo, ET9000, DM800se, TM5402, Sat BG, Viasat Latvia, JSC
Triax 1.1m, 43cm Motorised.
Archived: TM600, Eagle, Topfield 5000,TM6900
Find me near J15 M6
Have you tried using a Omnikey to read the card?
I have my Viasat Latvia / Lithuania card working in my Vu Duo
igor19
israel
What kind of omnikey do you recommend?
