dr hd f15 now updated new model called d15
wod
yorkshire
the dr hd f15 receiver used by many on the forum, now has an updated model called the d15
Now with much better cost. And faster CPU,too
Support of Wi-Fi with USB dongle
NTFS support for Mediaplayer
Playback of your media files streamed directly from your PC by home LAN
More energy-efficient and greener, low power consumption
Now with HDTV UI (graphics) by default
Fully HDTV and 3D compatible
Ultra-CAS Card Reader for different cards
Common Interface for CAMs
HD Media Player inside, supporting most popular formats and containers, including the MKV
HD PVR-ready
PVR records can be played on your PC without format conversion
SPECTRUM ANALYZER for effective DIY installation, and also for professional and DX use
Remote control has wide beam-range and buttons are fluorescent for greater comfort in the dark
LAN port to connect to Internet to remote servers and services; Wi-Fi (optional)
All the Linux-box features without Linux, faster and more stable
hxtp://dr-hd.com/product/receivers/dr-hd-d15-detail.html
dxhound2003
Az Box Premium.
Triax 110 cm dish motorised.
Black Ultra LNB. Nov 2011 DrD F15.
Dundalk Ireland
There are also details of two other Dr HD receivers on the link, Grand and Grand Triple (with three tuners). There is a good video about the Grand Triple.
interesting if it open the mux timb on 12.5w sport italy fta
BlindFaith
TBS 5925
you must be kidding :-beer
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
...Hmmm
Being one of the biggest fans of the original F15 ..I will wait to see if there as any real advantage to the 'ahem upgraded' ..box ..
Sounds like the gimmick level has increased but what about performance ?
No interest in wifi dongles ..or multituner support..
For DXers the all important features such as gain - lock stability..broadcast dvbs format support and storage space are paramount.
When I bought the F15 the exceptional gain was what sold it to me..
not the built in games ..etc.
Sometimes Less is More..
We shall see.
rgds
VS
wod
yorkshire
well even this new model is not available now, i had a look on the irish seller link from the dr hd site and its out of stock.
yes the tuner gain and this spectrum analyser thing is what got my interest. i missed out on the f15 and now looks like i've missed out on the new model, unless its in really short supply at the moment.
Is that the same website that says they are on vacation until August 18th ? :D
digi247
NW
see sig
I looked at this before deciding to go for the Grand Triple, and the only difference i can see is its a different CPU and the Tuners are the same as what are inside my Grand Triple so put all you F15 owners at ease Tuner sensitivity is exactly the same as the F15 no difference from what i can ascertain so far.
Also looking at the Specification it has lost the SD card reader and a USB port on the rear apart from that it pretty much identical, The speed has increased i noticed this with my Grand Triple over my F15 the scanning rate speed is incredibly fast, Blindscan is as the F15.
If you have the F15 stick with it Support is still there so why change
Robinson74
Motorised dish 45E - 30W, Clarke-Tech ET9000
Poland
Is there a manual available for this latest model, D15?
And one more thing. Does it support Ethernet connection using a wi-fi USB stick?
If so, does it have to be a particular manufacturer? A particular chipset?
Anyone know?
digi247
NW
see sig
There is a Russian manual available but for the life of me i cant remember where i came across it, Tests have been done on a 'Gi' branded USB wirless stick with success according to the russian support forum
Robinson74
Poland
As regards GI dongles, maybe it is one of those:
gi.ua/en/catalogue?page=shop.product_details&flypage=flypage.tpl&product_id=110&category_id=28
gi.ua/en/catalogue?page=shop.product_details&flypage=flypage.tpl&product_id=127&category_id=28
I don't think they are available where I live, though. Do you know of any other brands?
If you remember where you saw the Russian manual, I would be greatful for letting me know.
Any more information on D15 would be much appreciated from all who have got something to do with this model.
digi247
NW
see sig
As Requested the DrHD D15 User Manual Russian Language Only
Robinson74
Poland
Thank you, digi247.
If I decide to buy D15, I hope I can rely on you as regards a few tips and tricks. :-)
digi247
NW
see sig
Robinson74 said:
Thank you, digi247.
No Problem at all i personally own the Grand Triple but also had the F15 first and there are plenty of F15 owners on here who will gladly see you through any problems
Regards
wod
yorkshire
Robinson74 said:
Thank you, digi247.
I looked a while ago and the d15 was out of stock, has this changed ?
Robinson74
Poland
As far as I can see, the Irish supplier has 9 in stock.
It's missing a Scart socket! Useless to me as I need a decent RGB output for my Vulkano to stream...
Robinson74
Poland
As it only has one USB, I wonder if it would be possible to use an active USB hub in order to use a wi-fi USB dongle and a USB stick to record stream.
By the way, is recording to USB stick supported? Or does it have to be a decent USB HDD?
Because as I understand, it is not possible to accommodate an internal HDD?
hopper28
Astra 28.2 Blade 7000
ireland
I got one of these a few days ago great unit D15
I also have a Blade 7000
The one think that does not work is the 7 day EPG only now and next
I have been onto the factory about this who are trying to get it working
they have sent me a firmware for the F16 which will allow them to get the TP streams and sort this problem
but I dont have one of these units.
macx
tm6902hd-t2 super receiver
6ft c.master dish.
county down.
Have read the various comments regarding the D15, can you tell me as there is no scart how I would connect it to my existing units, Panasonic TH-42PZ70B TV, TM 6902HD receiver, and a Panasonic DMR-EX78EB DVD recorder.
thanks
macx.
