Rich-G
- Apr 27, 2010
- Age
- 41
- London
I have a 1 metre dish mounted on my terrace using a ground mount, it has a monobloc and all I want doing is the dish to be realigned to pick up Astra 19E and Hotbird 13E. As its a ground dish theres no drilling, no climbing ladders etc, should be a really easy job, 20 mins I would imagine, I just don't have a satellite finder or patience to do it myself.
The cable runs through my door using one of those "thin" type cables so the door can close without drilling a hole, I'm not sure if the cable still works so if the person doing the realignment could bring cable "just incase" then that would be excellent.
Thanks.
Thanks.
