TNTSat cards working in a Dreambox Status
sonic1
Vu + Ultimo 4K - Solo 4K - Uno 4K - Duo2- SoloSE - Zero- Uno -Prismcube Open Black Hole - 0.6 , 98cm Funkee , 28E-23.5E-19E-13E
Black Hole Team
Working fine with oscam and hypercam
Sent from my GT-I9300 using Tapatalk 2
Hmm Ive never had much luck with Oscam with anything, but I'll leave the Duo on TF1 for a bit
sonic1
Black Hole Team
Which image are you using ? Also with oscam you need the new aes key
Black Hole 1.6.4
July 24 2011
The OSCAMsloaded are ancient 1.10DVB-API & 4803.
sonic1
Black Hole Team
There is no reason why the latest hypercam wont load and work for you, pm and I will send it to you.
hairybadger
Bricoleur
46.1N 6.4E
see sig
OK - got it working with a recent Oscam and DVB-API. I can't get it to play nice with CCcam or Mgcamd as client - CCcam won't request the keys from Oscam and Mgcamd requests the keys then dies silently. The documentation available with these tools isn't particularly clear - I find IBM documentation a shining example of clear writing by comparison....
sonic1
Black Hole Team
Mgcamd will never work due to the ecm length but CCcam 2.3.0 should still be OK but I have not tested it.
hairybadger
Bricoleur
46.1N 6.4E
see sig
Ah, OK. That explains it :) Will have another fiddle with CCcam later.
