Help Required 9e ka-sat
Archive-8
Hi all, I have strapped my inverto ka-band lnb on to my op125 and at 9east I get signs of life. But only when I set the lof to universal.
10765 v 25000 S1. Most if the day it's been about 33% just checked now and it's down to 3%
So I will try and get a lock on this tomorrow.
Has any one else come across this please?
Is Saorsat known to be actually available in your location? The drop off on the Ka signals is incredibly steep.
excollier
Bikes, Booze, Rock & Blues
TD 64 and Humax Foxsat HDR with Raydon's custom firmware
County Donegal - furthest outpost of the EUSSR
I would guess that Dorset is much too far east for Saorsat. You aren't missing a great deal anyway, unless you have a specific interest in Irish current affairs, RTE One, RTE Two and TG4 - three channels. I live in Ireland and rarely watch them (RTE Two once a week because Big Bang Theory is a few weeks ahead, that's about it)
Archived-1
Persona non grata
uk
Hi Chris, I guess its just the chase ?, sorry I cant help with KA band, but at 37.5W you will get KU RTE feeds often, they are usually 4.2.2, one active at the moment 10977 V 2893.
Archive-8
I am At the Yeovil/Sherborne border. Yes I thought I was to far south. But my signal is back to 27% I will keep trying to lock on to it.
According to Lyngsat the symbol rate is 20185 not 25000
I think Yeovil is too far east for the Irish beam. Perhaps you're receiving something from the French beam - a so-called blocking signal? Same thing is happening on the Scottish beam, which is transmitting on the same frequency, overwhelming whatever signal you get from the Irish one.
Take a look at the map below. The purple lines are "absolute cut-off points" from whatever beam it borders. I am near Bristol and I am just inside the French beam zone... I haven't even bothered testing a Ka-LNB as I know I won't get anything from 9E.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Oh this old chestnut again ...
Gave up ages ago ..
Here's me at the crossroads...
Oh dear: Seems to be an Inverse-Venn Diagram.
Piltdownpaul
No.1 Spike Milligan Fan
Or likely Lord Lucan hideouts....
Archived-1
Persona non grata
uk
Ok your getting me hooked on KA :-doh, is there such a thing as a cheap lnb to have a go at at this please and a few others ?, I don't want to be spending too much as I will be kitting myself out with C band shortly and just bought a new STB.
Piltdownpaul
No need to encourage these sat companies to have more KA stuff Martin, they'll be using more and more spot beams and we dont want that do we?
Archived-1
Persona non grata
uk
I just find it interesting that I am on the edge of two beams, thinking about it I have a dish to take down and I am quite sure it has a KA lnb on it, first port of call I think:).
First mapped evidence of a North of England sub spot? ;) :-rofl2
Martin, no cheapo Ka-band LNBs, I am afraid. You can get the SL3 from the states for cheap but they need modifications. Check VS's extensive thread on his escapades.
