62E (Intelsat 902)
pride21
Sandown Isle of Wight
hi all did a scan on this sat besides ADEN on 11174H,11062H,11498H a new channel has popped up 11683H 14999 HD1 its a pity its scrambled.cheers
adonis1
Is it a new channel or just a feed ?
pride21
hi adonis i am not sure its not on flysat or lyngsat tried today but not a lot on due to rain, if its mpeg 4 then gain is not enough to bring in a signal,may be someone else could let us know.cheers
adonis1
OK , just try 10962H 5000 it's a powerfull signal .
Right now there is also a feed at 11601H 12500 , tagged as DTANG-1A
Done a scan of this and only getting 11063 H and 11176 H, with the former being quite strong on my 85cm dish.
pride21
hi CJ the only ones at the moment are 10962H 5000 at 97% quality,11063H 3100 91% quality,11166H 2500 71% quality,11170H 2200 77% quality,11177H 1100 90% quality and 11498H 4999 81% quality,others are showing quality strength but not locking.
keith100
Penta 85, Digipower SG-2100a motor, Icrecrypt S3200CCIHD, TBS5925, 13e to 66e
Aberdeen
The new Russian mux 11555 H 29700 is coming in well today - pity its not FTA
Archived-1
Persona non grata
uk
It will be nice to get around here, but unfortunately my dish needs raising a few ft to get over someone's roof,
To be rectified in the very near future.
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1.5 M
Dishes Gibertini 1.2 x2
Dish Gibertini 1 M
Malta
Pretty strong here
far78
1m Orbital and Supreme Intelligent Dark Motor, TBS 6925 and Tevii S464 PC cards, TM5402 M1
York, North Yorkshire
93% SQ on 11555H here :)
tempo
47.5N, 42.2E / Russia
12 db in my location
adonis1
killdeer
West Lancs UK
Technomate 5402 M1, Vu+Solo2, Humax Foxsats HD&HDR.
Triax TD110, Inverto Black Ultra.
90cm Fibo with Invacom 0.3dB LNB (not up and running yet.)
62 East to 61West
Lancs
Last week, I had my motorised td110 dish raise about 5 feet or so in an attempt to get the likes of 57E and maybe 62E.
To my delight, success was achieved with both of these to some extent. With 62E, I'm only managing to lock one transponder which is on the Spot2, European beam. The transponder involved is 11.555H, 29,700 and there is just one FTA channel, labelled as OTP, amongst the 28 that scan in.
The signal quality reading on my TM5402HD, M1, is prone to wild swings with this transponder, ranging from up to the high seventies down to below fifty when lock is lost. There are some trees in roughly the direction of the satellite and I presume that these are the cause of the fluctuations.
It's not only the trees (which may or may not be in the way), it's the fact that the satellite is quite low in the sky in UK and there is a lot more atmosphere for the signal to go through. Atmospheric conditions is what causes these swings.
If you manage to get 68.5E, the signal variations are even more intense!
Looks like it's gone - can someone check?
mar-val
Slovakia,Zilina
11555 H 29700 2/3
RikorSmart TV pack left
new TP-11015 H 25828 2/3 DVBS2/8PSK
russian channels ,encryption Verimatrix
zorbua
Dreambox 8000 HD
Dreambox 800se
Dreambox 900UHD
Clark Tech 5000 HD
Dish Gibertini 1 M
Malta
11555 H 29700 2/3
That's right, all there is Fta is Aden Live.
mar-val
Slovakia,Zilina
11555v Irib pack, possible with a big dish.;)
New TP - 11014H SR25829 FEC 2/3. Getting 12dB here on the 90cm.
Encrypted in Verimatrix apparently.
