Serious Power up tonight 16E ..and new MUX
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Just about every channel lockable
GolfeTV 10.5db
TFM 11.2db
Equinoxe 8.2db
Vision 4 13.2db
LTM 9.3db
LCF 11.5db
Sikka TV 9.7db
Impact TV (occasional lock) 6.4 db
most unusual ..
haven't locked TFM for some months ...and rarely locked LTM recently.
rgds
VS
attached a blindscan using the TBS card ..
previous db values from the F15
On the scan there -was- an unknown at 21553 sr 4166
damned if I can lock it ..
perhaps you can Llew ?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Ok ..managed a very brief lock on 21553 ..
it is a six channel mux (canal 2)
waiting for pix ..but here is the list captured on the F15
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
..5 TV and one radio ...
pix are hard to get and infrequent lock here ..but I managed some..
Signal increased to 8.1db and now a solid lock atm
Make that 4 TV and one 'Barker Channel' plus 1 radio
Sweet FM
I've been trying for that mux for a couple of days VS, max I can get is 6.5dB, no lock. Definitely a weak carrier. I'll have to try with the Inverto feedhorn, got the FD9000 on ATM. No prob with the other channels.
At first I thought my XMW had blown it on Saturday - this chump left it out without the cap on during a downpour (forgot to bring it in overnight), and it didn't work at all until I dried it out with a hot air fan :-doh
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
If it makes you feel any better I had a similar event some months ago ...water ingress due to a defect in the casting ..
I dabbed its internals with cotton buds ..warm air dried and resealed with silicon grease ..
It's been out in all weathers ever since without issue.
hope you lock it soon..
I've sent details to Flysat ...not sure I'll get there first though.
Good idea VS. I had noticed Elchromo had posted about it over at dxsat, so knew it was up. If I had given it some thought, I should have asked you to try for it. Sorry.
Yes, panic with the XMW. I remember your problem with it. I removed the covers both sides (24 screws, three different sizes) to see inside - dry thankfully. I think it was the entrance to the dipole that had got damp. Phew!
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Pretty solid here atm Llew
8.2 >8.4 db (F15) and locked more than unlocked though still getting strong gusts of wind from the west occasionally..
So that would explain the dropout.
rgds
VS
Slight OT, Evan, sorry but are all Ka-band transponders DVB-S2/8PSK (i.e. no DVB-S/QPSK)? Seems like a very healthy signal on most transponders that would easily lock in DVB-S/QPSK...
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Most of them are CJ ..
very narrow width channels and mostly 8PSK..
It can make for very tricky locking by F15 or TBS card ..and often missed in a blind scan
rgds
VS
rgds
VS
Up from 6.5dB to 7.6dB with a Triax feedhorn, but still no lock :(
All other TP's up 2dB too. I shall keep trying though; a bit overcast now, might come through in clearer conditions.
Is this a technical requirement due to the nature of high frequencies of the Ka-band ... or something else?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
8.1 (8db ) minimum lock level requirement I think Llew.
keep trying ..you're almost there.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
I don't think it -has- to be this way ..but as you know from looking at 17E Cband ..the African channel providers _tend_ to like low bit rate 8psk..
Not as far as I know. There's higher SRs on 19E, e.g. 15000SR (Penthouse) on 19E 18366V.
Laser
Which receiver would you recommend for Ka band?
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Any receiver will do ...
It's the lnbs that cost big money ..
As receivers go ...a high gain SD/HD stb like the F15 is more than adequate ..
but for Ka band D ...which this thread is discussing ..
£400 minimum ..and the XMW is more expensive still
Getting there. No video - yet.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
I too had dificulty getting video using the TBS card ..
Scan it with your F15 ..
It will give you more chance of images ..
8db on the TBS card for images ..but slightly less needed on the F15
rgds
VS
rgds
VS
F15 comes to the rescue. Poor quality snap, a transfer to my WinTV card.
Laser
Got 2 F15. Both new.
Will the new LNB do both Ku and Ka bands?
