17°East reception in south france?Ku band
rodscha
It seems we should be able to receive some interesting ku band stuff according to coverage maps
But Kingofsat only mentons C band for 17°East
anyone knows more?
11884 V 11761V & 11801 V on the west central beam should come to us...does it?
The official power getting into southern France on any of the beams is pretty feeble - 36dBW at best. That would suggest at least 2.4m dish is required, and much bigger for some of the beams.
rodscha
Thank you,I may then forget about it
I found it pretty convenient ,its being so close to 19°E astra 1!!
So,no TV5 Afrique for us!!
Archived-1
Persona non grata
uk
rodscha
I am getting a little sniff at 17E from my location on a 1.2 dish, i see you have a 1.3 you should stand a better chance than me in your location.
http://www.satellites.co.uk/forums/threads/receiving-amos-5-17e-in-the-uk.157064/page-3#post-907605
You will find more information @ flysat, give it a go you might get nothing you might get limited signals when conditions are good,
http://www.flysat.com/amos5.php
http://www.flysat.com/amos5-beam.php
Thanks a lot,prob is i 'm using the 1m20/30 for astra 2 (bbc etc)as a fixed dish,the one I can twiddle with is 80 cms only
Archived-1
Persona non grata
uk
You would be wasting your time with a 80cm then :(.
Anonymous_1
According to my experience.
in France , 1.80m is the minimum size for 11801, 11884 V , 12208H, 12216 V and 11041 V.
Anonymous_1
DW is FTA on 12260 V, not an amazing news for an FTA channel in Europe but..12260VDW.JPG .
Archive-8
Hi @martin-f what transponders do you get a sniff from please?
Archived-1
Persona non grata
uk
Hi Chris, you have to be careful here and not get confused with 19.2, most TP are the same,
From memory there is another thread somewhere and I posted the transponders there, I think I had a sniff at two but I had to chase them, I am sure my report is in the fringe threads pal if you want to take a look there, I am busy in the garden atm and just popped in for my tea. if you don't find it I will take a look later :)
Archived-1
Persona non grata
uk
