Lower Ka band Reception.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
The idiosyncrasies of Ka footprints never cease to amaze ..
Cheers Llew..
VS, can you check 19.2E? Something odd going on, or the heat's gone to my head.= or my LNB.
I can only find a new TP, at 18325 (present on V and H scans) and nothing else - all the usual TP's disappeared as I was scanning the spectrum.
...and this one on 18205- TV Radio Live Cinema. Can't see any video, and no CAT info, so not encrypted ??
Satelma and NTA now replaced ORTM...
Edit - Satelma is ORTM.
Back to the usual transponder frequencies now; don't know what was going on earlier (?)
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Sorry Llew ...System was compromised and still is whilst I am working on the Hughes HV switcher..
If it happens again ..let mr know and I'll try to check it out..
rgds
VS
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So ...even with my elevation control I can no longer find Ocko at 19.2E ...
I assume it has left ??
Not a low signal ...as there is simply no trace of a peak ..
Can you confirm Llew ?
Yes, gone again for me too. It does that sometimes. Probably pop up again later.
Newsnet feeds 18515V (using the Norsat LNB, SL3 off dish at present). TD88 dish.
Crazyscan 1.0.2.112
Streamreader 1.2.2.1257.
O/T, but I find the 1257 version locks ACM feeds better than the previous version.
Power has been well up on Newsnet this last couple of days, piddling down here at the mo and still 70% quality
That's what I thought, scopus. Usually my Norsat LNB underperforms compared to the SL3. I'll change LNBs tomorrow if conditions are still as good.
Archive-8
Crazyscan 1.0.2.112
I will look around for the stream reader dll. And have a really good go with it.
