Newbie Here Irte omnisat
Satman17
Skyhd
Ipswich
I'm looking for the above piece of kit, can anyone help me ?
gibertini
up north
DM800HDSE SIM 2.10 80CM ORBITAL FIXED@28.2E
53.6N 2.4W
good luck, the only chance you might have is someone having an old one in a shed or something or E*** but they are very rare nowadays
archive10
Why do you need this?
It has a problem with Skew if you get outside +/- 10 degrees, and is generally out-dated.
A H-H (DiSEqC) motor would be cheaper, higher performing and easier to obtain.
But perhaps there's a reason for the request?
It's useful for tracking things that don't require slew, such as WiFi.
A radio mast rotator would be easier to find though it does require a second cable to the roof.
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Also could be used for DVB-T antenna in case if there are several transmitting tower in range.
Or, for remote control surveillance camera.
Archived-1
Persona non grata
uk
I use mine for both Rimants :).
Tony1A
Never going back to Sky TV. Ever!
Somewhere In County Durham
Humax HDR1100S Freesat Recorder. Medion HD satellite box with Gibertini 1m motorised dish. Triax TD78 for Freesat. Triax TD64 for Freesat to 3 rooms. 2 Panasonic Freeview+ HD recorders.
North-East England, UK
I once had an IRTE multisat where the LNB moved across a bar driven by worm gear. It was OK for what it was, but 2 years later the damn thing broke. What a load of rubbish!
Ah I remember that moving LNB thing!
Retired Mod
www.timo.me.uk
I remember reading about the moving LNB in an old issue of What Sat. Never saw one for real though.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
