Newbie Here Hotbird 13 and Astra 28.2 with the same dish?
ojaysmoke
Icecrypt - Hotbird 13
manchester
I've never set up a satellite dish or anything as such and this will be my first time. I have an Icecrypt receiver connected to a dish, 80cm i think, pointed towards Hotbird 13e and it works fine.
However I want to get the Sky channels too which are on Astra 28.2.
Would it be possible for me to add another LNB to my current dish and receive both of them with the same dish?
If so, how hard will it be and would installing a new dish be easier?
Thanks in advance
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Hi Ojaysmoke
Welcome to the forum
Whilst a second lnb is often a possibility in these circumstances it really depend on the dish size and amount of patience you have and your line of sight. Both birds are reasonably powerful and I would tend to go with your focal point on 28.2E and picking 13E as the offset lnb. As I am not an installer or indeed very experienced in 2nd lnb's I would wait for a reply from someone more experienced, in the meantime have a search on the forum search utility for your needs or start with this thread
https://www.satellites.co.uk/forums/threads/my-sat-setup-part-2.161783/#post-902824
Dead easy to do - get something like this
http://tinyurl.com/ln24wem
hook the second lnb up, adjust for maximum signal, set the disecq switching arrangements up and away you go :)
Stick a third lnb in and you can have 19E as well :D
ojaysmoke
manchester
Thanks for all the replies. This way does seem very simple.
but which direction do I point the dish, do I keep it at hotbird 13e?
also how do I align the second LNB to get Astra 28.2? are there any guides on that?
For 13E / 28E keep it on 13E - 28E is higher powered here in the UK.
The best way to align the second lnb is simply to take an old portable tv outside and play with the lnb location until you nail it. With the main focus on 13E the offset for 28E will be left & up a bit as you face the dish. Across 4 or 5 inches will be about right, up an inch or so.
This is why those particular lnb clamps are ideal - quick and easy to setup with no real fiddling needed
ojaysmoke
manchester
thank you for all your help mate.
I assume this is the sort of lnb clamp you were referring to?
with this it seems that the LNBs will all be on the same line all facing straight ahead, will this not be a problem? I thought maybe the second LNB would have to be tilted to make sure its facing the centre of the dish, or does that not matter?
Retired Mod
www.timo.me.uk
I use those types of LNB brackets and they work well, but I tend to bend them ever so slightly so it focuses the LNB in a little to the centre. The metal is reasonably pliable.
Yup those are the ones - I ve got several and they are incredibly easy to use. As Timo says bend the brackets in a bit - stick the bracket over the end of a workbench and push gently on it until it gives a bit. It only needs to be in a little to improve the alignment towards the dish
Make sure you tighten the screws up well - the brackets will slip in time if you dont (been there!)
sab3082
southern england
Fracarro 85cm Penta motorised dish with INVERTO Ultra Twin Dual LMB ,
TM-5402-M3 receiver
portsmouth uk
Thanks in advance
Looks right to me
