The DirecTV SL3K4NR1-03
I can't replicate the changes with/without the feed in the Norsat I had previously - its tricky keeping the feed positioned with tape to hold it in. But there's definitely an increase in levels if I hold it in watching it at the dish with the analyser. I'll try again in a while.
Archive-8
No idea buddy ..
but the BBC pigtail is designed for use indoors..
Which is where I use mine
Just tried it outside, and I totally lost all signals.
Put it back behind the box, and still have the same problem. Re-wiring is not really an option for me atm.
The ber is always like that on newsnet.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
So ...this will be fun ...
and chances are it will be for nowt ..
But ..I would be a coward not to try.
My 3rd Trust feed as a Ka feed for the Norsat.
I have tapered the outer thickness of a short section of 10mm copper pipe to fit inside the waveguide of thwe Trust feed..
yes there will be small interior reuction to the feed ..but am hopefull this can be ignored.
Then am going to slide a cut section of a pvc travel bottle onto the tube..
Pot it up with liquid plastic..
and make a suitable WR fitting on the end of the copper tube to attach to the Norsat.
I'll be honest..
My heart just aint in this atm..
cest la vie
VS
Archive-8
[SATTYPE]
1=0192
2=Astra Ka-HV
3=0
4=20450
5=0
6=0
[DVB]
0=10
1=18367,V,15000,12,21,|-77 dBm, 2.5 dB
2=18412,H,6498,?,4,|-80 dBm, 5.2 dB
3=18508,V,3629,23,6,|-81 dBm, 2.4 dB
4=18520,V,3629,23,6,|-81 dBm, 4 dB
5=18524,V,3629,23,6,|-81 dBm, 2.7 dB
6=18540,V,3629,23,6,|-80 dBm, 3.1 dB
7=18558,V,3629,23,6,|-74 dBm, 4.9 dB
8=18562,V,2499,14,149,|-77 dBm, 6.1 dB
9=18569,V,999,34,148,|-75 dBm, 9 dB
10=18768,H,3109,12,149,|-80 dBm, 10.4 dB
Just found out that the TBS6983 Card will scan 18GHZ thanks to @CrazyCat
Evan - could you make up some sort of shield which could be temporarily rigged to shield you from various directions - out of the box (out of my tree possibly??) thinking - something like paint cans filled with concrete with garden canes embedded in them. then a chicken wire grid clipped to them with aluminium foil fastened to the chicken wire.
Archive-8
Do you mean a faraday cage?
Not all enveloping no - just a shield to experiment with blocking out certain directions
AS have you gotten into voodoo, or at least wearing an Alu hat? :D
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
[SATTYPE]
1=0192
2=Astra Ka-HV
3=0
4=20450
5=0
6=0
[DVB]
0=10
Can't help wondering Chris ...since you are seeing symptoms similar to mine..
Wot are all those extra (no locked) signals with no peaks around the newsnet part of the spectrum ???
could that be the shyte thats causing us problems ?
rgds
VS
Archive-8
rgds
VS
I think next doors modem and wifi and dect phone is the other side of the wall.
You may be right about it causing a lot of shite.
You'll have to come and live in rural Staffordshire with me..not much WiFi here and not a mobile mast for miles....
Further to my slightly bonkers idea yesterday I have a modification for the setup - the silver "thermal blankets" they use for rescues are metal covered plastic and a reasonable size to boot. Probably easier to handle than ali foil too and could be strung directly between supports.
About a fiver from Amazon
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Probably not one of my better constructs ..
As I said ..
But it should work ok ..
The blowlamp heat distorted the bottle end a bit ..but not high enough up to prevent level clamping on the dish ..
rgds
VS
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Just thought I'd re-hang the 03 on Carl ..and test with the new crazyscan ..
Still can't lock Newsnet ...but thought I'd share the ineresting spirograph image I got where Newsnet _would_ be..
lol
Nice one VS. Newsnet not locking here either.
Get a testcard on 18512V - I often find I lose Newsnet when I get a lock on other transmissions.
Newsnet still OK here. I have got my AZbox MiniMe back from Canada with the American firmware edition in, it has a very sensitive tuner with a a signal analyser page to boot....
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
The most I've seen here in almost a month..
Maybe the New TBS card will oaccasionally allow me access..
..only 7.2db here atm ..
but skies are clearing a bit..
Newsnet..
Forever a mystery ...
Archive-8
Newsnet..
What model card are you thinking of?
