Motor and switch on same receiver?
blackers
Gibertini 1.25, stab hh120,, vu+solo, tm5402hd, amiko micro hd, sky + hd full sub inc setanta..
Essex Uk
Hi guys, as the title suggests, is this possible?
How would I wire it?
Thanks in advance [emoji3]
What sort of switch are you referring to?
Also, can you provide a brief description of the antenna system?
If you're referring to a DiSEqC switch, then I have one in line between a Receiver and the Motor on one of my dishes and it happily passes the motor current without issue (They are normally specified up to 500mA pass-through). I have seen posts from others in the past claiming this destroys switches etc, but in all honesty haven't seen any supporting evidence.
blackers
Essex Uk
Sorry, yes a diseqc switch and a sg2100 motor is what I have. I have a 90cm dish on a motor which does me fine. Also I have a fixed 1.2m dish on 26e, I was hoping to combine the 2.
hassan M.saad
Samsung 46 inch LED Smart TV
VU+DUO2 Sat Receiver
Truman Sat Receiver Premier1+
STARGOLD FUJI Universal Prime Focus LNB
180 Cm Motorized Dish
Cairo, Egypt
Hello!
I hope you can help with the, I'm in Cairo, Egypt, I have the following
1. VU+DUO2 Sat Receiver
2. STARGOLD FUJI Universal Prime Focus LNB
3. 180 cm motorized Dish
4. 100 cm fixed primesat dish for 7.0°W, Nilesat
5. Topfield satellite dish Positioners
6. Jaeger 24-inch actuators
7. Black Hole Vu+ Duo2 2.1.5
Help Please With Tuner Configuration Setup on VU+DUO2
What I would like to do is to view a channel, say from Tuner A and record from say, Tuner B
Thank you so much for your support
Terryl
Custom built PC
It's best to rout the coax from the receiver directly to the motor first, then from the motor to any switch.
I use the good RG-6 quad coax with the pure copper center conductor when I wire up any motorized system, this way any voltage drop is kept to a minimum.
Mickha
North West
Hello!
Your post has now been copied to its own thread:
https://www.satellites.co.uk/forums/threads/vu-duo-2-motor-fixed-dish.164850/
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Personally I prefer to route thusly ..
LNB Doesn't pass through the motor ...but is seperated via T splitter ...
This method allows for multiple LNBs on a USALS motorised offset Dish with no loss introduced by the motor.
..and of course the motor current does not pass through the diseqc switch.
Just a personal preference really.
rgds
VS
