Wetek Android TV
Gizmondo
Dreambox DM500HD V2, Wetek Play
Manchester
Hi there!
I was thinking to buy this wetek box - h**p://www.wetek.com
Any of you guys ever heard about it?
I read some info and there are many people who are delighted with the device.
Thanks in advance
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Inverto c120 twin LNB
Central Scotland
Seems to be a versatile box with optional satellite and terrestrial tuners for about 10 euros each and you can plug in 2 at a time. It takes a hard disc too. I saw a video of it running 5.0.2 Lollipop (Unofficial Cyanogen MOD) and there are Linux images for it too. Wetek are a sponsor of Kodi.
I cannot find any reviews of its blind scan capability except that it does one.
Processor seems reasonably powerful in this price bracket.
There is a dedicated support forum.
If you do buy it please post a review.
Gizmondo
Manchester
hi AndyX
Thanks for the reply
I'm really thinking of buying it
If i don't like it, they have a refund in 15 days.
Not bad at all
I'm following their forum and they have many ways to use the box.
android, openElec, even ubunto (it's experimental).
Going to think through this weekend
Archived-1
Persona non grata
uk
Anyone here now using this box please ?.
CROSSBONES
S.Wales
I'm also thinking about getting this box. I have a mini-x at the moment which is really good and does 4K, the Wetek does not though.
Archived-1
Persona non grata
uk
Blind scan is more important to me than 4k CB, is the mini-x just a streamer please ?,
AndyX
Scotland
TM-F3/5
Octagon SF4800
Octagon SX88
Fibo Gregorian 1.2m
Motec Positioner
Central Scotland
Another alternative just coming available is the Amiko A3 Combo sat and cable
The A3 it replaces has blind scan. Not sure if this one will have one from the brief description. It is H265. If it does have H265 and blind scan it could be an interesting box.
CROSSBONES
S.Wales
It's an Android box Martin. Here's the spec........
Mini x neo 8
  • CPU: Amlogic S802-H Up to 2.0GHz (Cortex-A9)
  • GPU: 8 cores Mali450
  • Android 4.4.2 Kitkat OS, Built in Google Play Store
  • 2GB DDR3 RAM and 16GB emmc Storage
  • Build in external detachable SMA antenna, Great wifi signals;
  • Support Dual band wifi 2.4G & 5.8G (wifi module is Broadcom Ap6330)
  • Support Bluetooth 4.0 version
  • Support 4K*2K UHD video playback
  • Build in XBMC Minix version, support dolby dts hardware decodiing, also can play 4K, RMVB, Blueray ISO, MKV file without any problem
Archived-1
Persona non grata
uk
Thanks CB, I think I will go with the hybrid android with the dual sat tuner and see how it performs.
CROSSBONES
S.Wales
Yes good choice mate. Please let us know what you think of it.
CROSSBONES
S.Wales
Yes I hope so, Android and Linux together....the perfect match!
[Pedantic hat on]Android is a flavour of Linux[/pedantic hat off]
CROSSBONES
S.Wales
Rather than running typical Linux applications, Android uses the Dalvik virtual machine to essentially run applications written in Java.:)
